查看: 4021|回复: 15
[招聘] 【Synopsys武汉热招】DDR PHY digital design engineer
发表于 2015-7-15 16:47:32 | 显示全部楼层 |阅读模式
Job TitleSynopsys DDR PHY digital design engineer
LocationWuhan
Email:jobs-china@synopsys.com
Job description
This position is an ASIC/Digital Design Engineer whose mandate is to participate in the design of semiconductor integrated circuits in compliance with the project's specifications and Synopsys’ design methodologies. The successful candidate will work on a variety of design and verification tasks,incorporating such tasks as, and not limited to, RTL coding, behavioral coding,RTL simulation, synthesis, STA, gate-level simulation, formal verification,documentation, and proto type evaluation.
Documentation of functionality, code, verification environments/plans, and design procedures.
Write behavioral models and RTL code for circuit portions of integrated circuits.
Perform complex RTL simulations of circuits, interpret the results and optimize thecode until the predetermined functionality is satisfied.
Generate timing constraints for synthesizable designs.
May perform logic synthesis and/or static timing analysis.
Perform gate-level simulations of circuits, interpret the results and optimize thedesign until the predetermined functionality and timing is satisfied.
May participate in prototype evaluation using bench top laboratory instruments orautomated test equipment.
Communicate with other Synopsys employees regarding customer technical support.
May communicate directly with customers regarding technical support.
Other related duties as assigned by the manager.
Requirements
-A degree in Engineering or Applied Science (or equivalent)and 2+ years working experience in a related field.
-Familiarity with Verilog circuit design and design verification.
-Familiarity with synthesis, lint, CDC, STA and DFT.
-Familiarity with generation of timing constraints for ASIC designs.
-Knowledge of Perl/Shell/Makefile scripts.
-Knowledge of Design for Verification and Design for Low Power.
-Team player with good communication skills of both verbal and written English.
欢迎将简历投递到 jobs-china@synopsys.com.
 楼主| 发表于 2015-7-16 10:17:40 | 显示全部楼层
我是Synopsys的HR,
欢迎投递简历到jobs-china@synopsys.com
也可站短我,直接投简历到我邮箱
 楼主| 发表于 2015-7-17 09:20:39 | 显示全部楼层
欢迎关注,【Synopsys武汉】急招数字设计工程师,不错的机会~
 楼主| 发表于 2015-7-17 15:09:30 | 显示全部楼层
欢迎投递简历
 楼主| 发表于 2015-7-20 09:00:04 | 显示全部楼层
欢迎投递简历,加入Synopsys武汉研发中心
 楼主| 发表于 2015-7-21 15:30:26 | 显示全部楼层
Synopsys武汉急招DDR PHY数字设计工程师
 楼主| 发表于 2015-7-22 16:34:26 | 显示全部楼层
欢迎投递简历
 楼主| 发表于 2015-7-23 09:06:07 | 显示全部楼层
Synopsys武汉急招!
 楼主| 发表于 2015-7-24 09:51:59 | 显示全部楼层
 楼主| 发表于 2015-7-25 21:34:11 | 显示全部楼层
欢迎投递简历
GMT+8, 2025-9-23 15:13 , Processed in 0.025845 second(s), 6 queries , Gzip On, Redis On.
