查看: 3354|回复: 2
Temperature Compensation Of BJT Differential Amplifiers
发表于 2007-5-8 09:42:58 | 显示全部楼层 |阅读模式
The bipolar junction transistor (BJT) emitter-coupled differential-pair circuit is a familiar amplifier stage in the repertoire of analog designers, but has a surprising obscurity that needs to be revealed. This TechNote examines the emitter-circuit current source, I0, of BJT diff-amps and the effects on amplifier gain of different implementations for it.
The widespread belief that a BJT current source can temperature-compensate the diff-amp is true, but the conditions for it do not appear to be widely known, based on most designs.
col_050707.pdf
104.98 KB, 下载次数: 73 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-7-8 13:20:41 | 显示全部楼层
thanks
发表于 2007-7-12 17:28:52 | 显示全部楼层
thanks
GMT+8, 2025-10-3 21:49 , Processed in 0.015947 second(s), 6 queries , Gzip On, Redis On.
