查看: 10117|回复: 23
ESD Protection Design for Circuit with Mixed-Voltage I/O(M.D Ker)
发表于 2007-5-5 10:44:26 | 显示全部楼层 |阅读模式
ESD Protection Design for CMOS Integrated Circuits
with Mixed-Voltage I/O Interfaces
Ming-Dou Ker
Institute of Electronics
National Chiao-Tung University
Hsinchu, Taiwan
mdker@ieee.org
Abstract— With consideration on the gate-oxide reliability, the
new ESD protection design with ESD bus for 1.2/2.5-V mixedvoltage
I/O interfaces is reported by using the new proposed
high-voltage-tolerant power-rail electrostatic discharge (ESD)
clamp circuit. This proposed power-rail ESD clamp circuit
with only 1.2-V low-voltage NMOS/ PMOS devices can be
operated under the 2.5-V input conditions without suffering
the gate-oxide reliability issue. The experimental results in a
0.13-􀈝m CMOS process have confirmed that the proposed
power-rail ESD clamp circuit has high human-body-model
(HBM) and machine-model (MM) ESD robustness and fast
turn-on speed. The proposed power-rail ESD clamp circuit is
an excellent ESD protection solution to the mixed-voltage I/O
interfaces.
PRIME2006_WJChang_Ker.pdf
1.48 MB, 下载次数: 336 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-5-8 08:51:13 | 显示全部楼层
thanks for sharing
发表于 2007-9-16 14:37:02 | 显示全部楼层
謝謝你的分享
发表于 2007-9-30 20:15:14 | 显示全部楼层
发表于 2007-10-18 16:39:39 | 显示全部楼层
待业
发表于 2007-10-29 21:59:29 | 显示全部楼层
这个文件已经被损坏了,看不了
发表于 2007-10-29 23:22:31 | 显示全部楼层
好书啊
发表于 2008-3-22 10:06:37 | 显示全部楼层
thanks for sharing
发表于 2008-4-7 20:52:10 | 显示全部楼层
谢谢楼主,正需要呢!!!!!!!
发表于 2008-6-27 15:47:02 | 显示全部楼层
還不錯, 幫忙回覆一下 ~
GMT+8, 2025-12-24 16:48 , Processed in 0.022768 second(s), 9 queries , Gzip On, Redis On.
