查看: 4670|回复: 19
高压开关
发表于 2007-4-16 22:48:50 | 显示全部楼层 |阅读模式
本压缩包里头主要是一些IEEE上关于CMOS高压开关的论文。
A high voltage MOS switch
A high-voltage single-shot switch implemented with a MOSFET current source and avalanche diode
A new power transistor structure for improved switching performances
A novel compact high voltage triggerable switch
Analysis of high-voltage switching transistors by a two-dimensional mathematical model
Connie-a general AC-DC converter and transient circuit analysis program
Development of the 120 kV_70 A high voltage switching system with MOSFETs operated by simple gate control unit
Electromagnetic Capability Design of the High-Voltage Switch Electronic Power Conditioner in the Microwave Power Module
High performance modulators using MOSFETs
High voltage capacitor charging power supplies for repetitive rate loads
High voltage NMOS switching array with active pull-ups and low voltage addressing logic
High voltage switches for CMOS sub-micron EPROM
High-voltage LDMOS transistors fully compatible with a deep-submicron 0.35 μm CMOS process
High-voltage semiconductor devices_ status and trends
High-voltage switch using series-connected IGBTs with simple auxiliary circuit
High-voltage switching in the picosecond domain with laser activated semiconductor switches
Hot-carrier reliability of 20V MOS transistors in 0.13 μm CMOS technology
IEEE standard test code for high-voltage air switches. (Supplement_ switching-impulse testing of extra-high-voltage switches)
Optically isolated high-voltage digital-to-analog converter
Picosecond high voltage switching of a pressurized spark gap
The super junction bipolar transistor_ a new silicon power device concept for ultra low loss switching applications at medium to high voltages
Transient Voltage Sharing in Series Coupled High Voltage Switches
发表于 2007-4-16 23:02:34 | 显示全部楼层
包呢?在线等!
发表于 2007-4-17 08:23:46 | 显示全部楼层
?LZ,东西呢?
 楼主| 发表于 2007-4-17 21:36:39 | 显示全部楼层
不好意思啊,昨晚没粘上,没注意。
 楼主| 发表于 2007-4-17 21:40:00 | 显示全部楼层
不好意思啊,昨晚没粘上,没注意。
 楼主| 发表于 2007-4-17 21:48:05 | 显示全部楼层
不好意思啊,楼下的兄弟。
HVS01.rar
4.23 MB, 下载次数: 121 , 下载积分: 资产 -3 信元, 下载支出 3 信元
HVS
 楼主| 发表于 2007-4-17 21:51:21 | 显示全部楼层
不好意思啊,楼下的兄弟。
HVS02.rar
2.9 MB, 下载次数: 105 , 下载积分: 资产 -2 信元, 下载支出 2 信元
HVS
 楼主| 发表于 2007-4-17 21:54:19 | 显示全部楼层
不好意思啊,楼下的兄弟。
High-voltage semiconductor devices_ status and trends.pdf
3.87 MB, 下载次数: 100 , 下载积分: 资产 -2 信元, 下载支出 2 信元
HVS
 楼主| 发表于 2007-4-17 21:56:36 | 显示全部楼层
好了,总共这么多,没下着的兄弟对不住了啊。
发表于 2007-4-18 08:24:11 | 显示全部楼层
现在才看到!
GMT+8, 2025-12-22 14:36 , Processed in 0.034362 second(s), 6 queries , Gzip On, Redis On.
