查看: 8554|回复: 24
On-chip high voltage charge pump in
发表于 2007-4-11 21:47:11 | 显示全部楼层 |阅读模式
An on-chip high voltage tolerant 4VDD charge pump with symmetrical architecture in a standard low voltage 1.8 V 0.18 mm CMOS
process is presented. For a 250 kO load, circuit efficiency of the charge pump is approximately 71%. All the MOS transistors satisfy typical voltage stress related reliability requirements for standard low voltage CMOS devices.
01487738.pdf
91.01 KB, 下载次数: 228 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-9-29 20:59:50 | 显示全部楼层
发表于 2007-12-21 11:54:51 | 显示全部楼层
THANKS
发表于 2007-12-23 20:56:35 | 显示全部楼层
发表于 2008-7-23 13:38:48 | 显示全部楼层
多谢多谢
发表于 2008-8-20 00:39:24 | 显示全部楼层
太棒了
正好需要0.18um的charge pump參考資料
謝謝
发表于 2008-11-8 17:45:47 | 显示全部楼层
Thanks for sharing!
发表于 2008-11-8 17:48:33 | 显示全部楼层
Do you have anything book or papers on the dynamic analysis of charge pumps!
How to calculate the rising time and power consumption?
发表于 2008-12-1 11:47:43 | 显示全部楼层
多个电压的吗?
 楼主| 发表于 2008-12-20 22:00:32 | 显示全部楼层
It is a pity,my work focus mainly on the leakage reducdency of charge pump,。
And all my research was finished one year ago
GMT+8, 2025-12-28 00:33 , Processed in 0.022673 second(s), 6 queries , Gzip On, Redis On.
