查看: 12286|回复: 10
[招聘] 上市公司模拟和射频招聘内推
发表于 2015-5-29 22:11:47 | 显示全部楼层 |阅读模式
工作地点:深圳
上市公司招聘模拟IC和射频IC设计方向,欢迎提交简历到talent_analog@163.com,我会第一时间回复,谢谢。
Analog and/or RF IC Design Engineer
Job Description:
(1)    Design state-of-art analog/RF integrated circuit using most advanced CMOS process for consumer electrical product;
(2)    Evaluate circuit performance using instrument;
(3)    Volume production support for designs.
Qualifications:
(1)    MSEE or PhD in Electronic Engineering, Communication Engineering, and Microwave Engineering with at least 2 years experience; excellent fresh candidate can also be considerable;
(2)    Strong analog background in transistor level;
(3)    At least one of follow block design experience: PA, LNA, Mixer, PLL, VCO, DCXO, Bandgap, LDO, ADC and DAC;
(4)    Familiar with at deep-micro CMOS process such as 55nm and below;
(5)    Experience with EDA tools for circuit simulation and layout such as Spectre, Hspice,  ADS, Goldengate;
(6)    Proficient with EM modeling;
(7)    Experience with high frequency equipment such as network analyzer, spectrum analyzer, high frequency signal source,logic analyzer;
(8)    Knowledge of communication standards (Cellular, WLAN, BT etc) is highly desirable.
(9)    Knowledge of mix signal design (familiar with VHDL, verilog, verilog-A) is a plus.
发表于 2015-5-30 02:56:23 | 显示全部楼层
回复 1# krisger
Job Opportunity
友情帮顶
发表于 2015-5-30 08:08:07 | 显示全部楼层
友情帮顶
发表于 2015-5-30 08:49:40 | 显示全部楼层
什么公司啊?
发表于 2015-5-30 14:09:22 | 显示全部楼层
回复 4# gm-cfiltersz
    163的邮箱 当心受骗 起码也要是咨询公司的邮箱或者公司内部邮箱才能投
 楼主| 发表于 2015-6-1 22:37:52 | 显示全部楼层
回复 5# chengdumicro
   没有必要骗大家,只是个人申请的163邮箱,gmail现在不好用了。
用公司的邮箱不方便公布信息,请谅解。
发表于 2015-6-26 21:54:58 | 显示全部楼层
既然是招聘,又不敢把公司说出来?
发表于 2015-6-26 22:18:06 | 显示全部楼层
路过·····
发表于 2015-6-29 08:17:32 | 显示全部楼层
帮顶
NineCube 三维全波电磁场模拟解算器eWave是一款用来进行射频、数模混合信号芯片片上结构3D电磁仿真的软件。可以用来设计片上电感、变压器、电容、微带线、关键路径互联以及其他片上无源金属结构,是射频电缆、微波电路以及其他高性能的芯片设计不可缺少的仿真工具。eWave输入输出均采用业界通用的标准格式,可以自动从版图文件中读取待分析结构,以S-参数等多种形式输出分析结果。eWave采用MoM分析方法,结合用于分析衬底损耗的多层格林函数,可以求解任意形状的片上结构的电流或电场分布。
NineCube片上无源器件设计器ePCD是一个基于电磁场仿真软件的片上结构综合平台。可以用于片上螺旋电感、变压器、电容等的优化设计。综合平台的输入时用户希望达到的电路参数如电感值L和品质因数Q等以及可以优化的参数及其搜索空间范围,输出为片上结构的几何参数值和布好线的单元库。ePCD的全局和局部搜素相结合的算法保证了综合结果的最优,并行搜索算法使得综合效率与CPU个数成正比,大大加速了此类无源器件的设计过程,进而为RFIC和SoC的设计提供保障。
发表于 2015-10-11 16:59:58 | 显示全部楼层
什么公司
GMT+8, 2025-12-17 06:40 , Processed in 0.026428 second(s), 5 queries , Gzip On, Redis On.
