查看: 4372|回复: 6
[求助] [hspice]行为级DAC波形不理想,怎么修正,求助!!!
发表于 2015-5-11 10:47:44 | 显示全部楼层 |阅读模式
最上面的输出有刺
最上面的输出有刺
1.28us处的放大
1.28us处的放大
输出本应是严格阶梯状的,出现在在输入信号上升下降时
下面是网表
  1. ****Start ideal 8-bit DAC Subcircuit************************************
  2. .subckt DAC8bit VDD VREFP VREFM trip Vout B7 B6 B5 B4 B3 B2 B1 B0
  3. *Change input logic signals into logic 0s or 1s
  4. X7 trip B7 B7L Bitlogic
  5. X6 trip B6 B6L Bitlogic
  6. X5 trip B5 B5L Bitlogic
  7. X4 trip B4 B4L Bitlogic
  8. X3 trip B3 B3L Bitlogic
  9. X2 trip B2 B2L Bitlogic
  10. X1 trip B1 B1L Bitlogic
  11. X0 trip B0 B0L Bitlogic
  12. E1 VOUT 0 VOL='(v(VREFP)-v(VREFM))/256*(v(B7L)*128+v(B6L)*64+v(B5L)*32+v(B4L)*16+v(B3L)*8+v(B2L)*4+v(B1L)*2+v(B0L)*1+1/256)'
  13. .ENDS
  14. .subckt Bitlogic  trip BX BXL
  15. Vone one 0 DC 1.0
  16. Xa2 one BXL BX trip SW
  17. .ENDS
  18. ******会不会是下面这个模块不合适?**********.SUBCKT SW 1 2 3 4Gswitch 1 2 VCR PWL (1)  3 4 0V,10G 200pV ,1E-5
  19. R1 2 0 10G
  20. .ENDS
  21. ***main body*********
  22. VDD VDD 0 DC 1.0
  23. R2 VDD 0 10G
  24. VREFP VREFP 0 DC 1.0
  25. VREFM VREFM 0 DC 0.0
  26. VTRIP TRIP 0 DC 0.0
  27. VB7 B7 0 DC 0 pulse(1.0 0 0 200p 200p 1279.8n 2560n)
  28. VB6 B6 0 DC 0 pulse(1.0 0 0 200p 200p 639.8n 1280n)
  29. VB5 B5 0 DC 0 pulse(1.0 0 0 200p 200p 319.8n 640n)
  30. VB4 B4 0 DC 0 pulse(1.0 0 0 200p 200p 159.8n 320n)
  31. VB3 B3 0 DC 0 pulse(1.0 0 0 200p 200p 79.8n 160n)
  32. VB2 B2 0 DC 0 pulse(1.0 0 0 200p 200p 39.8n 80n)
  33. VB1 B1 0 DC 0 pulse(1.0 0 0 200p 200p 19.8n 40n)
  34. VB0 B0 0 DC 0 pulse(1.0 0 0 200p 200p 9.8n 20n)
  35. Xa1  VDD VREFP VREFM trip Vout B7 B6 B5 B4 B3 B2 B1 B0 DAC8bit
  36. R1 VOUT 0 10G
  37. .OPTION LIST NODE POST
  38. .OP
  39. .option runlvl=0
  40. .TRAN 200p 2.6u
  41. .PRINT DC  v(Vout)
  42. .END
    复制代码
 楼主| 发表于 2015-5-11 15:37:18 | 显示全部楼层
期待大家的帮助,谢谢!!!
 楼主| 发表于 2015-5-11 16:54:12 | 显示全部楼层
越高位变化时,毛刺越明显
修改后:
R1 2 0 1E-4
.ENDS
波形没有明显变化
发表于 2015-5-17 18:19:08 | 显示全部楼层
mmmmmmmm
发表于 2016-4-28 20:20:26 | 显示全部楼层
回复 1# xiecooller
Set runlvl=6 to get the most accuracy but at the cost of reduced simulation speed!
发表于 2018-11-14 10:25:58 | 显示全部楼层
学习中。。。。
发表于 2019-5-13 10:41:26 | 显示全部楼层
XXXXXXXXXXXXXXXX
GMT+8, 2025-12-21 13:20 , Processed in 0.024729 second(s), 7 queries , Gzip On, Redis On.
