查看: 4270|回复: 16
[原创] Predicting the Phase Noise and Jitter of PLL-Based Frequency Synthesizers
发表于 2015-5-10 20:34:52 | 显示全部楼层 |阅读模式
来自于国外微电子论坛的white paper. PLLnoise jitter.pdf (698.79 KB , 下载次数: 225 )
Two methodologies are presented for predicting the phase noise and jitter of a PLL-
based frequency synthesizer using simulation that are both accurate and efficient. The
methodologies begin by characterizing the noise behavior of the blocks that make up the
PLL using transistor-level RF simulation. For each block, the phase noise or jitter is
extracted and applied to a model for the entire PLL.
发表于 2015-5-11 11:58:10 | 显示全部楼层
Design With Operational Amplifiers
发表于 2015-5-11 23:53:51 | 显示全部楼层
非常感谢提供!
发表于 2015-5-12 14:56:36 | 显示全部楼层
http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf
发表于 2015-5-14 21:45:35 | 显示全部楼层
发表于 2015-5-14 23:10:46 | 显示全部楼层
PLL jitter analysis ~great
发表于 2015-12-29 00:17:03 | 显示全部楼层
多谢分享
发表于 2016-1-3 21:16:44 | 显示全部楼层
Thank you for sharing.
发表于 2016-3-3 09:33:37 | 显示全部楼层
thanks!
发表于 2016-3-17 18:54:58 | 显示全部楼层
GMT+8, 2025-12-26 19:15 , Processed in 0.021859 second(s), 6 queries , Gzip On, Redis On.
