查看: 3121|回复: 2
[求助] Verilog实现上升沿开始计数,下个上升沿停止计数
发表于 2015-5-7 18:39:02 | 显示全部楼层 |阅读模式
如题,用来测量脉冲信号周期,编译后错误是
Error (10133): Verilog HDL Expression error at Period.v(26): illegal part select of unpacked array "cnt"
程序如下:
module Period(
    clk,
    rst_n,
    signal,
    percounter
input clk, rst_n, signal;
output signed [9:0] percounter;
reg  [9:0] percounter;
reg  signal_reg;
reg  cnt[9:0];
wire signal_pos;
always @ ( posedge clk or negedge rst_n ) begin
     if ( !rst_n )  begin
         signal_reg <= 1'b0;
     end
     else begin
         signal_reg <= signal;
     end
end
assign signal_pos = signal & (~signal_reg);
     if ( !rst_n ) begin
         cnt[9:0] <= 10'd0;
     end
     else if ( signal_pos == 1'b1 ) begin
         cnt[9:0] <= 10'd0;
     end
     else begin
         cnt[9:0] <= cnt[9:0] + 10'd1;
     end
end
     if ( !rst_n ) begin
         percounter[9:0] <= 10'd0;
     end
         percounter[9:0] <= cnt[9:0];
     end
     else begin
     end
end
endmodule
求大神帮忙看看怎么改,不胜感谢~~
发表于 2015-5-7 20:02:18 | 显示全部楼层
reg  cnt[9:0]
reg [9:0] cnt
发表于 2015-5-8 09:00:06 | 显示全部楼层
module Period(
    clk,
    rst_n,
    signal,
    percounter
output [9:0] percounter;
reg  signal_reg;
reg  start;  //0 stop,1 start
wire signal_pos;
     if ( !rst_n )  begin
         signal_reg <= 1'b0;
     end
     else begin
     end
end
     if ( !rst_n ) begin
         start <= 1'b0;
     end
         start <= ~start;
     end
end
     if ( !rst_n ) begin
     end
     else if ( start == 1'b1 ) begin
          percounter <= percounter + 10'b1;
     end
     else begin
          percounter <= percounter ;
          //precounter <= 10'b0      ; //clr or keep
     end
end
endmodule
GMT+8, 2025-10-18 02:38 , Processed in 0.020511 second(s), 9 queries , Gzip On, Redis On.
