查看: 2250|回复: 5
[求助] place 之后cell 数量一下曾大很多 一般会这样么 如图
发表于 2015-4-25 10:58:34 | 显示全部楼层 |阅读模式
发表于 2015-4-26 09:48:05 | 显示全部楼层
report_design -physical 看看, place完了会增加20~30%的cell instance count的
 楼主| 发表于 2015-4-27 10:41:57 | 显示全部楼层
3q 大侠
 楼主| 发表于 2015-4-27 13:37:23 | 显示全部楼层
主要是 利用率 一下子 从65% 窜到了 85%
发表于 2015-4-28 00:42:16 | 显示全部楼层
Check how many buffers have been added (11102-112=~11000), that may be caused by many many HFN (high fanout net) in your synthesize netlist.
2 reasons I can imagine:
(1) poor qualify of synthesize netlist. (Maybe max_fanout, max_cap or WLM are not set correctly)
(2) poor floorplan causes a lot for detour in trial route, which increases estimated wireload and buffers are needed by the tool.
I would check the (1) first.
FYI.
 楼主| 发表于 2015-4-30 21:10:43 | 显示全部楼层
膜拜了 大神 前端 release 网表 确实问题很多  而且时序离约束差的很多  floorplan的话  design logic 比较简单  sram种类也很少 我再跟 fe沟通下 3q
GMT+8, 2025-12-20 12:22 , Processed in 0.018230 second(s), 7 queries , Gzip On, Redis On.
