查看: 1484|回复: 3
[求助] memory的输入没有约束
发表于 2015-4-17 23:26:48 | 显示全部楼层 |阅读模式
在report一个路径的timing时,发现memory的输入(DB[2])没有约束,这是怎么回事?
Path 1:Endpoint:   hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_dataxfer_1x_deRep_
fifo/u_deepcolor_fifo_block/u_deepcolor_fifo/DB[2] (v) (unconstrained output)
Beginpoint: hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_deepColorSM/phase_
reg_0_/Q                                           (v) triggered by  leading
edge of 'frxa_clk1x'
Arrival Time                    9.887
Analysis View: func_ss_wcv_125_cworst
     |                    Timing Point                    |     Arc      |      Cell       | Fanout |  Load |  Slew |  Edge |  User  |  Incr | Delay | Arrival |
     |                                                    |              |                 |        |       |       |       | Derate | Delay |       |  Time   |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | CK ^         |                 |     37 | 0.201 | 0.239 |   ^   |        |       |       |   3.248 |
     | deepColorSM/phase_reg_0_/CK ->                     |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | CK ^ -> Q v  | DFFRX4          |      7 | 0.056 | 0.154 |   v   | 1.000  | 0.000 | 0.599 |   3.847 |
     | deepColorSM/phase_reg_0_/Q                         |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/FE | A v -> Y v   | CLKBUFX2        |      4 | 0.048 | 0.248 |   v   | 1.000  | 0.006 | 0.317 |   4.164 |
     | _OCPC37221_n_59/Y                                  |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | B v -> Y v   | AND2XL          |      3 | 0.034 | 0.479 |   v   | 1.000  | 0.000 | 0.506 |   4.670 |
     | deepColorDecode/p0826A/Y                           |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | A v -> Y v   | AND4X2          |     23 | 0.096 | 0.409 |   v   | 1.000  | 0.035 | 0.565 |   5.234 |
     | deepColorDecode/g6328/Y                            |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | A v -> Y ^   | CLKINVX2        |     15 | 0.125 | 0.709 |   ^   | 1.000  | 0.000 | 0.530 |   5.765 |
     | deepColorDecode/Fp1072D6200/Y                      |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | A0N ^ -> Y ^ | AOI2BB2X2       |      1 | 0.077 | 0.884 |   ^   | 1.000  | 0.000 | 0.680 |   6.445 |
     | deepColorDecode/g6304/Y                            |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | B0 ^ -> Y v  | OAI2BB1XL       |      1 | 0.003 | 0.204 |   v   | 1.000  | 0.130 | 0.283 |   6.728 |
     | deepColorDecode/p1231D6088/Y                       |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | B v -> Y ^   | NOR3XL          |      1 | 0.012 | 0.624 |   ^   | 1.000  | 0.000 | 0.445 |   7.172 |
     | deepColorDecode/p1238D/Y                           |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | B ^ -> Y v   | NAND2X1         |      1 | 0.048 | 0.535 |   v   | 1.000  | 0.058 | 0.517 |   7.689 |
     | deepColorDecode/p0917D6061/Y                       |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | A0 v -> Y v  | AO22X2          |      1 | 0.143 | 0.621 |   v   | 1.000  | 0.110 | 0.868 |   8.557 |
     | dataxfer_1x_deRep_fifo/g1769/Y                     |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | A0N v -> Y v | OAI2BB1X2       |      1 | 0.115 | 0.618 |   v   | 1.000  | 0.024 | 0.677 |   9.234 |
     | dataxfer_1x_deRep_fifo/u_deepcolor_fifo_block/p080 |              |                 |        |       |       |       |        |       |       |         |
     | 9D770/Y                                            |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | A v -> Y v   | CLKBUFX2        |      1 | 0.084 | 0.403 |   v   | 1.000  | 0.100 | 0.640 |   9.874 |
     | dataxfer_1x_deRep_fifo/u_deepcolor_fifo_block/FE_O |              |                 |        |       |       |       |        |       |       |         |
     | FC37199_wire_9_2_/Y                                |              |                 |        |       |       |       |        |       |       |         |
     | hdmi_rx_top/hdmi_rx2/u_hdmi_backend/u_deepColor/u_ | DB[2] v      | deepc_FIFO_regf |        | 0.084 | 0.403 |   v   | 1.000  | 0.009 | 0.013 |   9.887 |
     | dataxfer_1x_deRep_fifo/u_deepcolor_fifo_block/u_de |              |                 |        |       |       |       |        |       |       |         |
     | epcolor_fifo/DB[2] ->                              |              |                 |        |       |       |       |        |       |       |         |
 楼主| 发表于 2015-4-17 23:30:05 | 显示全部楼层
这个memory的lib文件已经读进去了,没有发现warning或erro的问题。需要单独对memory设置约束选项吗?我使用的是edi
 楼主| 发表于 2015-4-18 00:17:26 | 显示全部楼层
综合时,也没发现问题
发表于 2015-4-18 08:20:23 | 显示全部楼层
sdc写的有问题, check_timing 看看, 没约束上, 不会优化的
GMT+8, 2025-8-20 09:11 , Processed in 0.015890 second(s), 6 queries , Gzip On, Redis On.
