查看: 12778|回复: 14
How to solve "Dumping VCS Annotated Stack" error???
发表于 2015-4-17 17:57:45 | 显示全部楼层 |阅读模式
There is a simple verilog file:
module test;
  initial begin
     $display("\nHello, World!\n");
  end
endmodule
when I run the vcs :   vcs -full64  +v2k -sverilog test.v -o simv -R
But after compilation, There is a stack error:
Dumping VCS Annotated Stack:
#0  0x00000031718ac8fd in waitpid () from /lib64/libc.so.6
#1  0x000000317183e909 in do_system () from /lib64/libc.so.6
#2  0x000000317183ec40 in system () from /lib64/libc.so.6
#3  0x00007f4541f2a515 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313e639d2928478c79b3f673f99203bcf8be64600612100082236bffb2007f1e0ef9 () from /home/Tools/vcs/amd64/lib/liberrorinf.so
#4  0x00007f4541f2bc52 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313efba706aab251478fa49e66610e453774633a6c152e7ef778f2202cda681f3d4e () from /home/Tools/vcs/amd64/lib/liberrorinf.so
#5  0x00007f4541f23b0d in SNPSle_d35ca1ff70d465c2b9b1a72eee90a506fdd009d3de3db1de () from /home/Tools/vcs/amd64/lib/liberrorinf.so
No context available
Note: Execution of simv exited with code 1
CPU time: .152 seconds to compile + .216 seconds to elab + .216 seconds to link + .580 seconds in simulation
The OS is RHEL 6.5, VCS is v201412sp1
Some nice guys, could you tell me how can I solve this problem?
发表于 2015-4-17 21:47:22 | 显示全部楼层
我也遇到了类似的问题。
redhat 7, vcsmax 201412.
发表于 2015-9-9 17:39:58 | 显示全部楼层
这个问题解决了吗?
发表于 2015-10-25 17:07:52 | 显示全部楼层
回复 2# jlqsczw_2007
  我也是跟你一样的,不知道你解决了吗?
VCS2014v12sp1 ,
64位的redhat7
vcs工程师demo下面的fifo工程,应该排除语法问题
Command line: ./simv -cm line +NUM+5
--- Stack trace follows:
#0  0xf7775430 in __kernel_vsyscall ()
#1  0xf2b57aeb in waitpid () from /lib/libc.so.6
#2  0xf2adcebe in do_system () from /lib/libc.so.6
#3  0xf2add2c5 in system () from /lib/libc.so.6
#4  0xf2d9b62b in system () from /lib/libpthread.so.0
#5  0xf73c4d0b in .
发表于 2015-10-27 14:47:22 | 显示全部楼层
回复 4# rxg111sc
   一样,解决没?
发表于 2015-10-31 11:07:32 | 显示全部楼层
回复 5# 洋大侠00
   不能解决,降级安装2014.03就可以了1~
发表于 2015-10-31 15:41:47 | 显示全部楼层
回复 6# rxg111sc
   哦,受教,谢谢
发表于 2015-12-14 11:18:47 | 显示全部楼层
我删掉上一次运行的结果文件,再跑一次就好了……
发表于 2016-1-8 16:17:24 | 显示全部楼层
同样的问题,再跑一次偶尔能过,概率很小。准备降版本试试。
VCS201412SP1
Ubuntu 14.04
发表于 2017-10-5 23:04:39 | 显示全部楼层
我有同样的问题。 有没有人修复这个错误?
GMT+8, 2025-12-17 22:44 , Processed in 0.021650 second(s), 5 queries , Gzip On, Redis On.
