查看: 12459|回复: 14
[求助] 有人给lib加过pg_pin吗?
发表于 2015-4-7 19:49:30 | 显示全部楼层 |阅读模式
不是用FRAM而是用TCL模式,按Synopsys Multivotage Flow User Guide的说法,read_db my_io.db
update_lib_voltage_model my_io \
    -voltage {VDD 1.1} \
    -voltage {VSS 0.0} \
    -voltage {VDDIO 1.9} \
    -voltage {VSSIO 0.0}
Error: Libraries are already loaded into memory; cannot remodel db libraries. (LIBSETUP-4000)
如果不read_db my_io.db,又会显示Error: Cannot read file 'your_library.db'. (UID-58)
服了Synopsys了
发表于 2015-4-8 09:45:41 | 显示全部楼层
你要做upf lib吧,
用下面的命令
icc_shell> add_pg_pin_to_lib -help
Usage: add_pg_pin_to_lib    # Run add_pg_pin_to_lib to convert non-pg_pin based .lib to pg_pin based .lib
        [-output output_lib_filename]
                               (generated pg_pin-based .lib file name)
        [-mw_library_name mw_library_name_list]
                               (list Milkyway library names)
        [-pg_map_file pg_pin_map_filename]
                               (pg_pin map file name)
        [-pg_map_template pg_pin_map_template_filename]
                               (file name of pg_pin map template)
        [-common_shell_path common_shell_path]
                               (common_shell path)
        [-expanded]            (generate expanded map template)
        [-fast]                (generate pg_pin library quickly)
        [-force_update]        (force update using user data)
        [-verbose]             (list details)
        input_lib_filename     (input non-pg_pin-based .lib file name)
icc_shell>
然后再写db,
发表于 2015-4-8 09:47:27 | 显示全部楼层
lpan.pdf (231.35 KB , 下载次数: 381 ) 见附件,先看看文档再说
 楼主| 发表于 2015-4-8 10:31:06 | 显示全部楼层
回复 3# icfbicfb
OK, 我先看看你发的文档
发表于 2016-5-8 22:05:55 | 显示全部楼层
谢谢分享
发表于 2020-1-6 17:31:15 | 显示全部楼层
Thanks
发表于 2021-4-27 14:42:13 | 显示全部楼层
谢谢,先看看
发表于 2021-7-13 15:44:14 | 显示全部楼层
thanks!!!!
发表于 2021-7-14 13:46:52 | 显示全部楼层
add_pg_pin_to_lib 这个命令在lc_shell里用不了?为什么?
发表于 2021-9-27 18:32:36 | 显示全部楼层
不清楚这命令为毛只在icc_shell里,另外新版的lc貌似只能保存db格式,lib我是死活调不出来了。。。
GMT+8, 2025-12-19 00:58 , Processed in 0.025257 second(s), 6 queries , Gzip On, Redis On.
