查看: 4570|回复: 0
[求助] calibre LVS 求助
发表于 2015-3-31 15:39:32 | 显示全部楼层 |阅读模式
cadence calibre LVS时出现“Components with non-identical signal pins”怎么解决。跪求啊!
                  ##         C A L I B R E    S Y S T E M         ##
                  ##             L V S   R E P O R T              ##
REPORT FILE NAME:         vga_pa.lvs.report
LAYOUT NAME:              /home/zhb/umc018/vga_pa.sp('vga_pa')
SOURCE NAME:              /home/zhb/umc018/vga_pa.src.net('vga_pa')
RULE FILE:                /home/zhb/umc018/_G-DF-MIXED_MODE_RFCMOS18-1.8V_3.3V-1P6M-MMC_CALIBRE-LVS-2.1-P2.txt_
RULE FILE TITLE:          LVS of UMC 0.18um 1.8V/3.3V 1P6M MMCMixed Mode/RFCMOS Process
CREATION TIME:            Tue Mar 31 15:21:10 2015
CURRENT DIRECTORY:        /home/zhb/umc018
USER NAME:                zhb
CALIBRE VERSION:          v2011.3_18.12    Wed Aug 10 15:03:23 PDT 2011
                               OVERALLCOMPARISON RESULTS
                    #           #    INCORRECT     #
Error:    Components withnon-identical signal pins.
Warning:  Unbalanced smashedmosfets were matched.
                                      CELL  SUMMARY
Result         Layout                        Source
CORRECT        vga_pa                        vga_pa
                                      LVSPARAMETERS
o LVS Setup:
   //LVS COMPONENT TYPE PROPERTY
   //LVS COMPONENT SUBTYPE PROPERTY
   //LVS PIN NAME PROPERTY
  LVS POWER NAME                        "?VDD?" "?VCC?"
  LVS GROUND NAME                       "?VSS?" "?GND?"
  LVS CELL SUPPLY                       NO
  LVS RECOGNIZE GATES                   ALL
  LVS IGNORE PORTS                      NO
  LVS CHECK PORT NAMES                  YES
  LVS IGNORE TRIVIAL NAMED PORTS        NO
  LVS BUILTIN DEVICE PIN SWAP           YES
  LVS ALL CAPACITOR PINS SWAPPABLE      NO
  LVS DISCARD PINS BY DEVICE            NO
  LVS SOFT SUBSTRATE PINS               NO
  LVS INJECT LOGIC                      YES
  LVS EXPAND UNBALANCED CELLS           YES
  LVS FLATTEN INSIDE CELL               NO
  LVS EXPAND SEED PROMOTIONS            YES
  LVS PRESERVE PARAMETERIZED CELLS      NO
  LVS GLOBALS ARE PORTS                 YES
  LVS REVERSE WL                        NO
  LVS SPICE PREFER PINS                 NO
  LVS SPICE SLASH IS SPACE              YES
  LVS SPICE ALLOW FLOATING PINS         YES
   //LVS SPICE ALLOW INLINE PARAMETERS
  LVS SPICE ALLOW UNQUOTED STRINGS      NO
  LVS SPICE CONDITIONAL LDD             NO
  LVS SPICE CULL PRIMITIVE SUBCIRCUITS  NO
  LVS SPICE IMPLIED MOS AREA            NO
   //LVS SPICE MULTIPLIER NAME
  LVS SPICE OVERRIDE GLOBALS            NO
  LVS SPICE REDEFINE PARAM              NO
  LVS SPICE REPLICATE DEVICES           NO
  LVS SPICE SCALE X PARAMETERS          NO
  LVS SPICE STRICT WL                   NO
   //LVS SPICE OPTION
  LVS STRICT SUBTYPES                   NO
  LVS EXACT SUBTYPES                    NO
  LAYOUT CASE                           YES
  SOURCE CASE                           YES
  LVS COMPARE CASE                      NAMES TYPES SUBTYPES VALUES
  LVS DOWNCASE DEVICE                   NO
  LVS REPORT MAXIMUM                    50
  LVS PROPERTY RESOLUTION MAXIMUM       32
   //LVS SIGNATURE MAXIMUM
// LVS FILTER UNUSED OPTION
   //LVS REPORT OPTION
  LVS REPORT UNITS                      YES
   //LVS NON USER NAME PORT
   //LVS NON USER NAME NET
   //LVS NON USER NAME INSTANCE
   //Reduction
  LVS REDUCE SERIES MOS                 NO
  LVS REDUCE PARALLEL MOS               YES
  LVS REDUCE SEMI SERIES MOS            NO
  LVS REDUCE SPLIT GATES                YES
  LVS REDUCE PARALLEL BIPOLAR           YES
  LVS REDUCE SERIES CAPACITORS          YES
   LVSREDUCE PARALLEL CAPACITORS         YES
  LVS REDUCE SERIES RESISTORS           YES
  LVS REDUCE PARALLEL RESISTORS         YES
  LVS REDUCE PARALLEL DIODES            YES
  LVS REDUCTION PRIORITY                PARALLEL
  LVS SHORT EQUIVALENT NODES            NO
   //Trace Property
  TRACE PROPERTY  mn(N_18_G2)  l l 7
  TRACE PROPERTY  mn(N_18_G2)  w w 7
  TRACE PROPERTY  mp(P_18_G2)  l l 7
  TRACE PROPERTY  mp(P_18_G2)  w w 7
  TRACE PROPERTY  mn(N_18_MM)  l l 3
  TRACE PROPERTY  mn(N_18_MM)  w w 3
  TRACE PROPERTY  mp(P_18_MM)  l l 3
  TRACE PROPERTY  mp(P_18_MM)  w w 3
  TRACE PROPERTY mn(N_LV_18_MM)  l l 3
  TRACE PROPERTY mn(N_LV_18_MM)  w w 3
  TRACE PROPERTY mp(P_LV_18_MM)  l l 3
  TRACE PROPERTY mp(P_LV_18_MM)  w w 3
  TRACE PROPERTY  mn(N_33_G2)  l l 3
  TRACE PROPERTY  mn(N_33_G2)  w w 3
  TRACE PROPERTY  mp(P_33_G2)  l l 3
  TRACE PROPERTY  mp(P_33_G2)  w w 3
  TRACE PROPERTY  mn(N_33_MM)  l l 3
  TRACE PROPERTY  mn(N_33_MM)  w w 3
   TRACEPROPERTY  mp(P_33_MM)  l l 3
  TRACE PROPERTY  mp(P_33_MM)  w w 3
  TRACE PROPERTY mn(N_LV_33_MM)  l l 3
  TRACE PROPERTY mn(N_LV_33_MM)  w w 3
  TRACE PROPERTY mp(P_LV_33_MM)  l l 3
  TRACE PROPERTY mp(P_LV_33_MM)  w w 3
  TRACE PROPERTY  mn(N_ZERO_18_MM)  l l 3
  TRACE PROPERTY mn(N_ZERO_18_MM)  w w 3
  TRACE PROPERTY mn(N_ZERO_33_MM)  l l 3
  TRACE PROPERTY mn(N_ZERO_33_MM)  w w 3
  TRACE PROPERTY mn(N_BPW_18_MM)  l l 3
  TRACE PROPERTY mn(N_BPW_18_MM)  w w 3
  TRACE PROPERTY  mn(N_BPW_33_MM)  l l 3
  TRACE PROPERTY mn(N_BPW_33_MM)  w w 3
  TRACE PROPERTY mn(N_PO7W500_18_RF)  l l 3
  TRACE PROPERTY mn(N_PO7W500_18_RF)  w w 3
  TRACE PROPERTY mp(P_PO7W500_18_RF)  l l 3
  TRACE PROPERTY mp(P_PO7W500_18_RF)  w w 3
  TRACE PROPERTY mn(N_PO7W500_33_RF)  l l 3
  TRACE PROPERTY mn(N_PO7W500_33_RF)  w w 3
  TRACE PROPERTY mp(P_PO7W500_33_RF)  l l 3
  TRACE PROPERTY mp(P_PO7W500_33_RF)  w w 3
  TRACE PROPERTY mn(N_L18W500_18_RF)  l l 3
  TRACE PROPERTY  mn(N_L18W500_18_RF)  w w 3
  TRACE PROPERTY mp(P_L18W500_18_RF)  l l 3
  TRACE PROPERTY mp(P_L18W500_18_RF)  w w 3
  TRACE PROPERTY mn(N_L34W500_33_RF)  l l 3
  TRACE PROPERTY mn(N_L34W500_33_RF)  w w 3
  TRACE PROPERTY mp(P_L34W500_33_RF)  l l 3
  TRACE PROPERTY mp(P_L34W500_33_RF)  w w 3
  TRACE PROPERTY mn(N_PG400_G2)  l l 3
  TRACE PROPERTY mn(N_PG400_G2)  w w 3
  TRACE PROPERTY mn(N_PD400_G2)  l l 3
  TRACE PROPERTY mn(N_PD400_G2)  w w 3
  TRACE PROPERTY  mp(P_L400_G2)  l l 3
  TRACE PROPERTY  mp(P_L400_G2)  w w 3
  TRACE PROPERTY mn(N_PG1020_G2)  l l 3
  TRACE PROPERTY mn(N_PG1020_G2)  w w 3
  TRACE PROPERTY mn(N_PD1020_G2)  l l 3
  TRACE PROPERTY mn(N_PD1020_G2)  w w 3
  TRACE PROPERTY mp(P_L1020_G2)  l l 3
  TRACE PROPERTY  mp(P_L1020_G2)  w w 3
  TRACE PROPERTY c(VARMIS_18_RF)  nf nf 3
  TRACE PROPERTY  c(VARDIOP_RF)  nf nf 3
  TRACE PROPERTY  r(RSNWELL)  r r 3
  TRACE PROPERTY  r(RSND)  r r 3
  TRACE PROPERTY  r(RSPD)  r r 3
  TRACE PROPERTY  r(RSNPO)  r r 3
  TRACE PROPERTY  r(RSPPO)  r r 3
  TRACE PROPERTY  r(RNND_MM)  r r 3
  TRACE PROPERTY  r(RNPD)  r r 3
  TRACE PROPERTY  r(RNNPO)  r r 29
  TRACE PROPERTY  r(RNNPO_MM)  r r 3
  TRACE PROPERTY  r(RNNPO_RF)  r r 3
  TRACE PROPERTY  r(RNPPO)  r r 66
  TRACE PROPERTY  r(RNPPO_MM)  r r 3
  TRACE PROPERTY  r(RNPPO_RF)  r r 3
  TRACE PROPERTY r(RNHR1000_MM)  r r 3
  TRACE PROPERTY  r(RNHR_RF)  r r 3
  TRACE PROPERTY  r(RM1_MM)  r r 3
  TRACE PROPERTY  r(RM2_MM)  r r 3
  TRACE PROPERTY  r(RM3_MM)  r r 3
  TRACE PROPERTY  r(RM4_MM)  r r 3
  TRACE PROPERTY  r(RM5_MM)  r r 3
  TRACE PROPERTY  r(RM6_MM)  r r 3
  TRACE PROPERTY  d(DION_G2)  p p 3
  TRACE PROPERTY  d(DION_G2)  a a 3
  TRACE PROPERTY  d(DIOP_G2)  a a 3
  TRACE PROPERTY  d(DIOP_G2)  p p 3
  TRACE PROPERTY  d(DIONW_G2)  a a 3
  TRACE PROPERTY  d(DIONW_G2)  p p 3
  TRACE PROPERTY  d(DION_MM)  a a 3
  TRACE PROPERTY  d(DION_MM)  p p 3
  TRACE PROPERTY  d(DIOP_MM)  a a 3
  TRACE PROPERTY  d(DIOP_MM)  p p 3
  TRACE PROPERTY  d(DIONW_MM)  a a 3
   TRACEPROPERTY  d(DIONW_MM)  p p 3
  TRACE PROPERTY q(PNP_V50X50_G2)  a a 3
  TRACE PROPERTY q(PNP_V100X100_G2)  a a 3
  TRACE PROPERTY q(PNP_V50X50_MM)  a a 3
  TRACE PROPERTY q(PNP_V100X100_MM)  a a 3
  TRACE PROPERTY  c(MIMCAPS_MM)  c c 3
   TRACEPROPERTY  c(MIMCAPM_RF)  c c 3
  TRACE PROPERTY l(L_SLCR20K_RF)  d d 3
  TRACE PROPERTY l(L_SLCR20K_RF)  n n 3
  TRACE PROPERTY l(L_SLCR20K_RF)  w w 3
COMPONENT TYPES WITH NON-IDENTICAL SIGNALPINS
     (Cells with the same ( or corresponding ) name that have differentsignal
      pin names are listed below.  Pinsthat do not appear in all corresponding
      cells in both source and layout are ignored by the comparisonalgorithm.)
Layout Component Type:  R (3 pins): (p n) sub
Layout Extra Pins:      sub
Layout Component Type:  R (2 pins): (p n)
No Extra Pins.
Source Component Type:  R (3 pins): (p n) sub
Source Extra Pins:      sub
                   CELL COMPARISON RESULTS (TOP LEVEL )
                         #       ###################       _  _
                   #   #        #     CORRECT    #         |
                    # #          #                 #       \___/
LAYOUT CELL NAME:         vga_pa
SOURCE CELL NAME:         vga_pa
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:             10        10
Nets:              70        29   *
Instances:        228        15   *    MN (4 pins)
                    10        10         C (2 pins): p n
                     8        8         C (3 pins): p n sub
                     6         6         R (2 pins)
                    28        12   *    D (2 pins)
                     1         1         L (3 pins)
Total Inst:       281        52
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:             10        10
Nets:              22        22
Instances:          3         3         MN (4 pins)
                     4         4         C (3 pins): p n sub
                     6         6         R (2 pins)
                    12        12         D (2 pins)
                     1         1         L (3 pins)
                     4         4         _smn2v (4 pins)
Total Inst:        40        40
      * = Number of objects in layout different from number in source.
                               INFORMATION ANDWARNINGS
                  Matched    Matched   Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source   Type
  Ports:              10         10            0            0
  Nets:               22         22            0            0
  Instances:           2          2            0            0   MN(N_18_MM)
                        1          1            0            0   MN(N_33_MM)
                       10         10            0            0   C(PAD_RF)
                        4          4            0            0   C(MIMCAPM_RF)
                        2         2            0            0   R(RNHR1000_MM)
                        4          4            0            0   R(RNND_MM)
                       12         12            0            0   D(DIOP_MM)
                        1          1            0            0   L(L_SLCR20K_RF)
                        4          4            0            0   _smn2v
  Total Inst:         40         40            0            0
o Statistics:
   228 layout mos transistors were reduced to11.  44 connecting nets were deleted.
    129 mos transistors were deleted by parallel reduction.
    88 mos transistors and 44 connecting nets were deleted by split-gatereduction.
   6source mos transistors were reduced to 2. 2 connecting nets were deleted.
    4 mos transistors and 2 connecting nets were deleted by split-gatereduction.
   7parallel layout capacitors were reduced to 3.
   7parallel source capacitors were reduced to 3.
   20parallel layout diodes were reduced to 4.
   1source net had all its pins removed and was deleted.
o Initial Correspondence Points:
  Ports:        V_ctr1 V_ctr2 V_ctr3gnd vdd33 vdd18 L1 L4 vin vout
o Matched Mosfets Which Have Been UnequallyReduced:
      X101/M28(859.450,425.850)                                 MM6
      X101/M29(859.450,424.470)                                 MM2
      X99/M0(859.450,329.990)                                   MM4
      X99/M1(859.450,328.610)                                  ** missing smashedmosfet **
      X99/M2(859.450,327.230)                                   ** missingsmashed mosfet **
      X99/M3(859.450,325.850)                                   ** missingsmashed mosfet **
      X99/M4(859.450,324.470)                                   ** missingsmashed mosfet **
      X99/M5(859.450,323.090)                                   ** missingsmashed mosfet **
      X99/M6(859.450,321.710)                                   ** missingsmashed mosfet **
      X99/M7(859.450,320.330)                                   ** missingsmashed mosfet **
      X99/M8(859.450,318.950)                                   ** missingsmashed mosfet **
      X99/M9(859.450,317.570)                                   ** missing smashed mosfet **
      X99/M10(859.450,316.190)                                  ** missingsmashed mosfet **
      X99/M11(859.450,314.810)                                  ** missingsmashed mosfet **
      X99/M12(859.450,313.430)                                  ** missingsmashed mosfet **
      X99/M13(859.450,312.050)                                  ** missingsmashed mosfet **
      X99/M14(859.450,310.670)                                  ** missingsmashed mosfet **
      X99/M15(859.450,309.290)                                  ** missingsmashed mosfet **
      X99/M16(859.450,307.910)                                  ** missingsmashed mosfet **
      X99/M17(859.450,306.530)                                  ** missingsmashed mosfet **
      X99/M18(859.450,305.150)                                  ** missingsmashed mosfet **
      X99/M19(859.450,303.770)                                  ** missingsmashed mosfet **
      X99/M20(859.450,302.390)                                  ** missingsmashed mosfet **
      X99/M21(859.450,301.010)                                  ** missingsmashed mosfet **
      X99/M22(859.450,299.630)                                  ** missingsmashed mosfet **
      X99/M23(859.450,298.250)                                  ** missingsmashed mosfet **
      X99/M24(859.450,296.870)                                  ** missingsmashed mosfet **
      X99/M25(859.450,295.490)                                  ** missing smashed mosfet **
      X99/M26(859.450,294.110)                                  ** missingsmashed mosfet **
      X99/M27(859.450,292.730)                                  ** missingsmashed mosfet **
      X99/M28(859.450,291.350)                                  ** missingsmashed mosfet **
      X99/M29(859.450,289.970)                                  ** missingsmashed mosfet **
      X100/M0(859.450,396.390)                                  ** missingsmashed mosfet **
      X100/M1(859.450,395.010)                                  ** missingsmashed mosfet **
      X100/M2(859.450,393.630)                                  ** missingsmashed mosfet **
      X100/M3(859.450,392.250)                                  ** missing smashed mosfet **
      X100/M4(859.450,390.870)                                  ** missingsmashed mosfet **
      X100/M5(859.450,389.490)                                  ** missingsmashed mosfet **
      X100/M6(859.450,388.110)                                  ** missingsmashed mosfet **
      X100/M7(859.450,386.730)                                  ** missingsmashed mosfet **
      X100/M8(859.450,385.350)                                  ** missingsmashed mosfet **
       X100/M9(859.450,383.970)                                  ** missingsmashed mosfet **
      X100/M10(859.450,382.590)                                 ** missingsmashed mosfet **
      X100/M11(859.450,381.210)                                 ** missingsmashed mosfet **
      X100/M12(859.450,379.830)                                 ** missingsmashed mosfet **
      X100/M13(859.450,378.450)                                 ** missingsmashed mosfet **
      X100/M14(859.450,377.070)                                 ** missing smashedmosfet **
      X100/M15(859.450,375.690)                                 ** missingsmashed mosfet **
      X100/M16(859.450,374.310)                                 ** missingsmashed mosfet **
      X100/M17(859.450,372.930)                                 ** missingsmashed mosfet **
      X100/M18(859.450,371.550)                                 ** missingsmashed mosfet **
      X100/M19(859.450,370.170)                                 ** missingsmashed mosfet **
      X100/M20(859.450,368.790)                                 ** missingsmashed mosfet **
      X102/M27(907.090,425.850)                                 MM7
      X102/M28(907.090,424.470)                                 MM1
      X102/M29(907.090,423.090)                                 MM3
      X103/M0(907.100,328.610)                                  ** missingsmashed mosfet **
      X103/M1(907.100,327.230)                                  ** missingsmashed mosfet **
      X103/M2(907.100,325.850)                                  ** missingsmashed mosfet **
      X103/M3(907.100,324.470)                                  ** missingsmashed mosfet **
      X103/M4(907.100,323.090)                                  ** missingsmashed mosfet **
      X103/M5(907.100,321.710)                                  ** missingsmashed mosfet **
      X103/M6(907.100,320.330)                                  ** missingsmashed mosfet **
      X103/M7(907.100,318.950)                                  ** missingsmashed mosfet **
      X103/M8(907.100,317.570)                                  ** missingsmashed mosfet **
      X103/M9(907.100,316.190)                                 ** missingsmashed mosfet **
      X103/M10(907.100,314.810)                                 ** missingsmashed mosfet **
      X103/M11(907.100,313.430)                                 ** missingsmashed mosfet **
      X103/M12(907.100,312.050)                                 ** missingsmashed mosfet **
      X103/M13(907.100,310.670)                                 ** missingsmashed mosfet **
      X103/M14(907.100,309.290)                                 ** missingsmashed mosfet **
      X103/M15(907.100,307.910)                                 ** missingsmashed mosfet **
      X103/M16(907.100,306.530)                                 ** missingsmashed mosfet **
      X103/M17(907.100,305.150)                                 ** missing smashed mosfet **
      X103/M18(907.100,303.770)                                 ** missingsmashed mosfet **
      X103/M19(907.100,302.390)                                 ** missingsmashed mosfet **
      X103/M20(907.100,301.010)                                 ** missingsmashed mosfet **
      X103/M21(907.100,299.630)                                 ** missingsmashed mosfet **
      X103/M22(907.100,298.250)                                 ** missingsmashed mosfet **
      X103/M23(907.100,296.870)                                 ** missingsmashed mosfet **
      X103/M24(907.100,295.490)                                 ** missingsmashed mosfet **
      X103/M25(907.100,294.110)                                 ** missingsmashed mosfet **
      X103/M26(907.100,292.730)                                 ** missingsmashed mosfet **
      X103/M27(907.100,291.350)                                 ** missingsmashed mosfet **
      X103/M28(907.100,289.970)                                 ** missingsmashed mosfet **
      X103/M29(907.100,288.590)                                 ** missingsmashed mosfet **
      X104/M0(907.100,395.010)                                  ** missing smashed mosfet **
      X104/M1(907.100,393.630)                                  ** missingsmashed mosfet **
      X104/M2(907.100,392.250)                                  ** missingsmashed mosfet **
      X104/M3(907.100,390.870)                                  ** missingsmashed mosfet **
      X104/M4(907.100,389.490)                                  ** missingsmashed mosfet **
      X104/M5(907.100,388.110)                                  ** missingsmashed mosfet **
      X104/M6(907.100,386.730)                                  ** missingsmashed mosfet **
      X104/M7(907.100,385.350)                                  ** missingsmashed mosfet **
      X104/M8(907.100,383.970)                                  ** missing smashed mosfet **
      X104/M9(907.100,382.590)                                  ** missingsmashed mosfet **
      X104/M10(907.100,381.210)                                 ** missingsmashed mosfet **
      X104/M11(907.100,379.830)                                 ** missingsmashed mosfet **
      X104/M12(907.100,378.450)                                 ** missingsmashed mosfet **
      X104/M13(907.100,377.070)                                 ** missingsmashed mosfet **
       X104/M14(907.100,375.690)                                 ** missingsmashed mosfet **
      X104/M15(907.100,374.310)                                 ** missingsmashed mosfet **
      X104/M16(907.100,372.930)                                 ** missingsmashed mosfet **
      X104/M17(907.100,371.550)                                 ** missingsmashed mosfet **
      X104/M18(907.100,370.170)                                 ** missingsmashed mosfet **
      X104/M19(907.100,368.790)                                 ** missing smashedmosfet **
                                        SUMMARY
Total CPU Time:      0 sec
Total Elapsed Time:  0 sec
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 06:30 , Processed in 0.017706 second(s), 7 queries , Gzip On, Redis On.
