查看: 3159|回复: 1
[求助] UVM输出hello world问题
发表于 2015-3-23 20:36:49 | 显示全部楼层 |阅读模式
运行的时候输入vsim -c -sv_lib $UVM_HOME/lib/uvm_dpi work.hello_world_example结果显示
# Loading sv_std.std
# Loading work.uvm_pkg(fast)
# Loading work.hello_world_example(fast)
# ** Note: (vsim-8785) UVM-aware debugging capabilities will be disabled since no compiled "questa_uvm_pkg" can be found.
# This also means that later if you turn on UVM-aware debugging your debug simulations may have
# different random seeds from your non-debug simulations.
# Loading d:/uvm/verilog_src/uvm-1.1d/lib/uvm_dpi.dll
求问是什么问题啊?gcc吗?
 楼主| 发表于 2015-3-23 21:29:27 | 显示全部楼层
大神们不要来了,我错了,原来我没有运行,我是傻叉!
GMT+8, 2025-12-13 00:02 , Processed in 0.017182 second(s), 5 queries , Gzip On, Redis On.
