查看: 3924|回复: 1
[求助] 求助UVM带参数接口的问题
发表于 2015-3-22 10:51:10 | 显示全部楼层 |阅读模式
我定义了一个带参数的接口,接口中的参数写的是"BLUE",在top中例化了三次接口,参数分别为“BLUE”,“GREEN”,"RED",blue可以过,后两个参数都报下面的错误,求大神解决!!
Error-[ICTTFC] Incompatible complex type usage
top_tb.sv, 66
  Incompatible complex type usage in task or function call.
  The following expression is incompatible with the formal parameter of the
  function. The type of the actual is 'interface encode_if#("GREEN")', while
  the type of the formal is 'virtual interface encode_if#("BLUE")'.
  Expression: top_tb.ch1_if
  Source info: uvm_config_db#(encode_if#("BLUE"))::set(null,
  "uvm_test_top.drv1", "vif", top_tb.ch1_if)
发表于 2015-3-23 15:31:09 | 显示全部楼层
GMT+8, 2025-12-18 07:30 , Processed in 0.020725 second(s), 5 queries , Gzip On, Redis On.
