查看: 4644|回复: 6
新手求指导,用hspice仿真了个简单的反相器
发表于 2015-3-17 17:04:48 | 显示全部楼层 |阅读模式
stimulate之后总是出现如下错误,求大神指导
**warning** (models.sp:2)  model nmos device geometries will not be checked against the limits set by lmin, lmax, wmin and wmax. To enable this check, add a period(.) to the model name(i.e. enable model selector).
  **warning** (models.sp:74)  model pmos device geometries will not be checked against the limits set by lmin, lmax, wmin and wmax. To enable this check, add a period(.) to the model name(i.e. enable model selector).
**error**  extra numerical data on above line
  **error** (c:\synopsys\fangzhen\buffer.sp:9) difficulty in reading input
          ***** job aborted
 楼主| 发表于 2015-3-17 17:08:46 | 显示全部楼层
不能沉啊
 楼主| 发表于 2015-3-17 17:10:38 | 显示全部楼层
求指导
 楼主| 发表于 2015-3-17 17:17:01 | 显示全部楼层
这是编的文件
 楼主| 发表于 2015-3-17 17:24:48 | 显示全部楼层
顶贴啊,顶贴
 楼主| 发表于 2015-3-17 21:08:51 | 显示全部楼层
别沉啊,就指导一下啊
发表于 2022-11-24 16:18:41 | 显示全部楼层
7年了。我又碰到同样问题了,老哥现在搞懂了吧,方便给小弟解答下吗,嘿嘿
GMT+8, 2025-12-29 05:02 , Processed in 0.023915 second(s), 9 queries , Gzip On, Redis On.
