查看: 2125|回复: 2
[求助] EDI10破解失败
发表于 2015-3-11 21:51:33 | 显示全部楼层 |阅读模式
我从版上下载的EDI110,将sfk copy到安装目录下,然后source ./patch_cadence
开始运行,输出log,结果
warn : empty file: data/feBldTcl11.11-s101.ngt - skipping
warn : empty file: data/anlsRedist11.11-s013lnx86.ngt - skipping
warn : empty file: data/cdnCryptUtil64b11.11-e010lnx86.ngt - skipping
warn : empty file: data/anlsRedistPub11.11-s013lnx86.ngt - skipping
warn : empty file: data/tsiCommon11.11-s198lnx86.ngt - skipping
warn : empty file: data/fetut4dfII11.11-s001.ngt - skipping
warn : empty file: data/fe11.11-s101lnx86.ngt - skipping
warn : empty file: data/ccopt01.80-s013lnx86.ngt - skipping
warn : empty file: data/anlsRedistPubIndep11.11-s013.ngt - skipping
warn : empty file: data/anlsVPSPub11.11-s013lnx86.ngt - skipping
warn : empty file: data/iotaIndep03.00-p004.ngt - skipping
warn : empty file: data/anlsVPS64b11.11-s013lnx86.ngt - skipping
warn : empty file: data/NanoRouteEMS11.11-s004.ngt - skipping
warn : empty file: data/rcCommon11.10-s016lnx86.ngt - skipping
warn : empty file: data/makecdb64b11.11-s198lnx86.ngt - skipping
warn : empty file: data/FF_PROTO11.11-s001.ngt - skipping
warn : empty file: data/anlsLibTablePlugin64b11.11-s013lnx86.ngt - skipping
warn : empty file: data/feCommon11.11-s101lnx86.ngt - skipping
warn : empty file: data/cdnCryptUtil11.11-e010lnx86.ngt - skipping
warn : empty file: data/rcIndep11.10-s016.ngt - skipping
warn : empty file: data/anlsRedistCommon11.11-s013lnx86.ngt - skipping
warn : empty file: data/celticFEEtc11.11-s198.ngt - skipping
warn : empty file: data/syntechEtc11.11-s002.ngt - skipping
warn : empty file: data/exe - skipping
warn : empty file: data/makecdbIndep11.11-s198.ngt - skipping
warn : empty file: data/celticDMFEEtc11.11-s198.ngt - skipping
warn : empty file: data/anlsVPSCommon11.11-s013lnx86.ngt - skipping
34875 files checked, 53 changed.
2 errors, 420 warnings occurred.
请教大家,可能是什么原因?
 楼主| 发表于 2015-3-12 14:24:43 | 显示全部楼层
49% fms/etc/fmsLibDataCreaterror: failed to read+write: sfk - skipping
74% mmsim/ahdl/lib/64bit/ahdlondemand_sh.so : 0warn : cannot read:
 楼主| 发表于 2015-3-12 15:28:17 | 显示全部楼层
解决办法:
安装
libXp-1.0.0-8.1.el5.x86_64.rpm
openmotif-2.3.1-5.el5_6.2.x86_64.rpm            两个rpm包
GMT+8, 2025-12-26 07:44 , Processed in 0.021555 second(s), 7 queries , Gzip On, Redis On.
