查看: 2947|回复: 2
[转贴] Ambit Buildgates, Envisea Silicon Ensemble and Cadence SoC Encounter
发表于 2015-3-10 03:36:57 | 显示全部楼层 |阅读模式
Hi all,
I decided to learn Backend design and I am investigating some EDA tool. I found a lots of tools from different Eda vendor doing the job and I feel confused. For example, could you please tell me what is the difference between Ambit Buildgates, Envisea Silicon Ensemble and Cadence SoC Encounter ?
Thanks in advance.
发表于 2015-3-10 22:09:27 | 显示全部楼层
ambit buildgate is cadence synthesis tools. currently it has been out-of-date for long time
if you want to learn synthesis , you should learn Design Compiler which is gold synthesis tool from Synopsys
Envisea Silicon Ensemble is cadence P&R tools,  it is also out-of-date. you should learn EDI (soc encounter latest version) or IC compiler from Synopsys
发表于 2019-7-29 21:46:14 | 显示全部楼层
Thanks
GMT+8, 2025-9-19 05:47 , Processed in 0.013785 second(s), 5 queries , Gzip On, Redis On.
