查看: 2700|回复: 1
[解决] DAT to TXT
发表于 2015-1-15 21:36:33 | 显示全部楼层 |阅读模式
hello
i want to use the ecg file which is in DAT format but i want it to be in txt format
can anybody plz tell me how to convert it
thanks
发表于 2015-1-16 04:14:18 | 显示全部楼层
try notepad++ editor, it can open most files.  Remove the necessary the format script in your .dat file. Then force change the file type to .txt by renaming the file.  I did this to data generated by Rsoft.
Hope this works.
GMT+8, 2025-9-14 03:02 , Processed in 0.013161 second(s), 4 queries , Gzip On, Redis On.
