查看: 4077|回复: 1
[求助] 菜鸟求教,第一次用verilog hdl编程,出了点问题
发表于 2015-1-11 13:50:13 | 显示全部楼层 |阅读模式
Info: *******************************************************************
Info: Running Quartus II 64-Bit Analysis & Synthesis
Info: Version 11.0 Build 157 04/27/2011 SJ Full Version
Info: Processing started: Sun Jan 11 10:56:12 2015
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off phrase -c phrase
Info: Parallel compilation is enabled and will use 2 of the 2 processors detected
Error (10839): Verilog HDL error at phrase.v(3): declaring global objects is a SystemVerilog feature
Error (10170): Verilog HDL syntax error at phrase.v(8) near text "input";  expecting ";"
Info: Found 0 design units, including 0 entities, in source file c:/users/1169294388/desktop/phrase.v
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 373 megabytes
Error: Processing ended: Sun Jan 11 10:56:17 2015
Error: Elapsed time: 00:00:05
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 4 errors, 0 warnings
程序如下
//stan 基准数字信号,tob待测数字信号,clk时钟信号,outs输出相位
parameter N=9,M=20;//2^8<360,2^9>360;20bit
module phrase(stan,tob,clk,outs)
//变量
input stan,tob,clk;
output [N:1] outs;
reg [N:1] outs;
wire c0,c1,c2,c3;//c0是基准数字信号与待测数字信号异或的结果,c1是c0与时钟信号与的结果,c2是基准信号二分频的结果,c3是c2与clk与的结果,用来测基准信号相对于clk的时间周期
reg [20:1] count1,count2,cont1,cont2;//count1是测基准信号时间的,count2是测c0的高电平时间的
count1=0;
count2=0;
//实现异或
assign c0=((!stan)&&tob)||(stan&&(!tob));
assign c1=c0&&clk;
always@(posedge stan)
begin
assign c2=!c2;
end
assign c3=c2&&clk;
//测c0高电平时间
和测c3高电平时间
always@(posedge c1 or posedge c3)
begin
if(c1)
count2=count2+1;
if(c3)
count1=count1+1;
end
always@(negedge c0 or negedge c2)
begin
#2 if(!c0)
cont2=count2;
count2=0;
#2 if(!c2)
cont1=count1;
count1=0;
outs=cont2/cont1;
display("现在的相位是=%0d度",outs);
end
endmodule
发表于 2015-1-11 14:44:18 | 显示全部楼层
改一下,再試看看:
module phrase(stan,tob,clk,outs);
//变量
祝好運!
GMT+8, 2025-12-29 04:30 , Processed in 0.022304 second(s), 6 queries , Gzip On, Redis On.
