查看: 2858|回复: 1
[求助] I created the text (drawing ) in mos ,but it can't attatch in mos
发表于 2015-1-5 16:10:54 | 显示全部楼层 |阅读模式
attatch in mos ,So I uesd the skill see below :
but When I load "CCSattachLabels.il"  in  CIW
there are the syntax error  (  syntax error in line 5 column 3 of file) ,  What is the problem ?
procedure( CCSattachLabels()
   let( (cv allLabels x1 y1 box inst)
      cv=geGetWindowCellView()
      allLabels=setof(x cv~>shapes x~>objType=="label")
      foreach( label allLabels
         x1=car(label~>xy)
         y1=cadr(label~>xy)
         box=list(x1:y1 x1+0.001:y1+0.001)
         inst=car(dbProduceOverlapInst(cv box))
         leAttachFig(label inst)
         printf("Attached label %s at %L to inst %s\n" label~>theLabel label~>xy inst~>name)
      ) ;foreach
   ) ;let
) ;procedure
发表于 2015-3-1 11:34:23 | 显示全部楼层
帮你改了一下 貌似可以了
procedure( attach()
   let( (cv allLabels x1 y1 box inst x)
      cv=geGetSelectedSet()
      cv1 =geGetWindowCellView()
allLabels = list()
      foreach(shap cv
if(shap~>objType == "label" then
allLabels = cons( shap allLabels)
else nil
         x1=car(label~>xy)
         y1=cadr(label~>xy)
         inst=car(dbProduceOverlapInst(cv1 box))
      ) ;foreach
   ) ;let
) ;procedure
GMT+8, 2025-12-10 06:45 , Processed in 0.020771 second(s), 6 queries , Gzip On, Redis On.
