DRC LVS 均通过,PEX提参数0 error 0 warning但是进行后仿真时提示calibre view不存在,如下
ERROR (OSSHNL-108): The property, 'connectivityLastUpdated', specified on library 'ADPLL_layout', cell 'var_corase_bank_with_driver',
view 'calibre', does not have an integer value. Re-extract the design (File->Check
and Save menu option) to correct this error.
End netlisting Dec 23 16:41:58 2014
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all or,if a netlist was produced, it might be corrupt.Fix the reported errors and generate the netlist again.
...unsuccessful
然后进入calibre view ,check & save 后显示提取出的电路有错,有电容short到了管子的漏极 ,如下所示:
...unsuccessful.
INFO (SCH-1170): Extracting "var_corase_bank_with_driver calibre"
Error: Net "c_43627_p" shorted to net "I6_I1_I2_MPM1@6_d".
Error: Net "I6_I1_I7_MPM1@2_d" shorted to net "c_50599_p".
Error: Net "I6_I1_I4_MPM1@9_d" shorted to net "c_13165_p".
Error: Net "c_13165_p" shorted to net "I6_I1_I4_MPM1@9_d".
Error: Net "c_50599_p" shorted to net "I6_I1_I7_MPM1@2_d". |
