查看: 3912|回复: 5
[求助] Ubuntu14.04安装CadenceIC615求助
发表于 2014-12-10 23:29:03 | 显示全部楼层 |阅读模式
悬赏1资产未解决
小弟是个小白,不得不自己搞定这个软件,按照贴吧找到的方法和安装包尝试了一下,现在出现了这么个情况,如下:
Located CDROM at /usr/tmp/cadence616/CDROM1
The tar command to use is: /bin/tar -x -b 1 -f -
Specify path of install directory [OR type [RETURN] to exit]: /eda
Checking your system for InstallScape...
Could not detect InstallScape for lnx86 platform using the PATH environment variable.
It is recommended to have only one Installation of InstallScape
for lnx86 platform. If an InstallScape installation exists
please help us find it.
Do you have InstallScape for lnx86 platform installed[y/n]?n
You are on lnx86 platform
InstallScape version 04.21.s02
for platform lnx86
is available on this media.
Do you want to install InstallScape for lnx86 [y/n]?y
It is recommended that you install InstallScape
outside the Cadence installation hierarchy
and include the ~iscape/bin in your PATH environment variable.
Type the path to InstallScape installation directory [ (q to quit)]: /eda/Installation
InstallScape installation directory: /eda/Installation
Extracting InstallScape version 04.21.s02
for platform lnx86 in /eda/Installation
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0
If you do not see the InstallScape console
window or it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/eda/Installation/iscape/bin/iscape.sh /usr/tmp/cadence616/CDROM1:::/eda
Initializing InstallScape using JVM at /eda/Installation/iscape.04.21-s002/runtime/LNX86/bin/java. This might take some time...
/eda/Installation/iscape/bin/iscape.sh: 219: exec: /eda/Installation/iscape.04.21-s002/runtime/LNX86/bin/java: not found
接下来我该怎么办完全不知道了。。。求各位大神来帮帮我吧
发表于 2014-12-26 15:27:15 | 显示全部楼层
遇见过这个问题,没有解决;后来单独安装了CentOS;建议楼主直接换RedHat吧
发表于 2014-12-28 12:05:01 | 显示全部楼层
ubuntu安装IC 61X,参考:
http://getglitched.com/?page_id=143
INSTALL CADENCE 6.1 ON UBUNTU 10.04.pdf
340.52 KB, 下载次数: 93 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2017-11-19 12:16:44 | 显示全部楼层
thank you
发表于 2018-5-3 09:55:35 | 显示全部楼层
Thanks a lot!
发表于 2018-6-9 19:39:45 | 显示全部楼层
good job
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 18:22 , Processed in 0.014617 second(s), 4 queries , Gzip On, Redis On.
