查看: 7608|回复: 12
[求助] Layout XL (IC 5.1.41) routing
发表于 2014-12-10 15:02:53 | 显示全部楼层 |阅读模式
Kindly  People:
I'm using Layout XL (IC 5.1.41) function for routing use .
Has also been set up>    icc.rules,
But when I chose create> wire,
Create Wire form did not displayed, why?
Who can help me?
 楼主| 发表于 2014-12-10 15:15:57 | 显示全部楼层
回复 1# james0933
    You can google  the  >  layout_xl_cic   file
and  in  Page 11  ,you can find the auto placement function !
发表于 2014-12-10 15:46:51 | 显示全部楼层
Any message in CIW?
 楼主| 发表于 2014-12-11 14:10:23 | 显示全部楼层
回复 3# question23
    There were several warning messages in CIW  as  below :
1. *WARNING* Export from DFII:Techfile param iccLayers is not defined.
2. *WARNING* Export from DFII:Cannot export (jj comp layout) from DFII .
                       The iccLayers section is nil.empty or undefined in techfile or rules file .
3. *WARNING* Error during layer table initialization .
4. *WARNING* Unable to load design data : library jj cell COMP view layout
5. *WARNING* Write Editor library unavailable for 'command_start' command
6. *WARNING* WE : Failed to init .
发表于 2014-12-11 16:48:42 | 显示全部楼层
回复 4# james0933
    Can you find iccLayers in your icc.rules ?
 楼主| 发表于 2014-12-11 17:09:51 | 显示全部楼层
回复 5# question23
    Yes,there are iccLayers in my icc.rules.
发表于 2014-12-11 17:40:53 | 显示全部楼层
回复 6# james0933
    How did you set up the icc.rules in VXL?
Options - Routing - Rules
 楼主| 发表于 2014-12-12 10:45:19 | 显示全部楼层
回复 7# question23
    When I choosen the   ,  Optios > Routing  then ,
1.  set up Rules  >  browse  the  icc.rules
2.  Refresh  >  ok
3. Create  >  wire
4.  in CIW   messages
*WARNING*  Illegal layer function diffusion specified in  (("DIFF"  "drawing")  "diffusion" "off" 0.16 0.2 nil t).
*WARNING*  Error during layer table initialization.  jj cell COMP view layout
*WARNING*   Unable to load design data.library jj cell COMP view layout
*WARNING*   Wire Editor library UNAVAILABLE FOR 'COMMAND_START' command
*WARNING*  WE: Failed to init.
5.   What happened to  icc.rules ?
thank you  kindly help .         James
发表于 2014-12-12 11:07:05 | 显示全部楼层
回复 8# james0933
    Please try to change diffusion to n_diffusion in icc.rlues file. Good luck.
发表于 2014-12-12 11:09:12 | 显示全部楼层
回复 8# james0933
    You can get more information in document 'Virtuoso® Custom Placement and Routing Preparation Guide'
GMT+8, 2025-12-26 10:01 , Processed in 0.024568 second(s), 5 queries , Gzip On, Redis On.
