谢版主回复。我说的就是drc的问题 Specifies a maximum transition time for the specified clock groups, ports ordesigns 这是guide 关于set_max_transiton的定义,按字母解释应该是可以约束clock的
set_clock_tree_option
-max_transition transition_time
Specifies the maximum transition time design rule constraint in main library
unit for the buffers and inverters used while compiling the specified clock
trees.
I think it is easy to understand if you know what is CTS.
