我的 lib_link.path中关于命名规则的语法如下:
set bus_dimension_separator_style "_"
define_name_rules rule2 -restricted "\!\@\#\$\%\^\&\*\(\)\\\/\-\"\{\}" -case_insensitive -map {{{"%s[%d]","%s_%d"}}} -type port -target_bus_naming_style "%s_%d"
define_name_rules rule3 -remove_port_bus
define_name_rules rule4 -case_insensitive -map {{{"_reg[%d]","_reg_%d"}}}
run.dc.tcl文件中关于命名规则的语法如下:
set bus_naming_style {%s[%d]}
change_names -rules verilog -hierarchy
change_names -rule rule2 -hierarchy
change_names -rule rule3 -hierarchy
change_names -rule rule4 -hierarchy
write -format verilog -hierarchy -output ./report/$module.net
写出来的.net文件
HDR_DRNQ_1 q_reg_1_ ( .D(din_0), .CK(clk), .RDN(rst_n), .Q(q_1) );
HDR_DRNQ_1 q_reg_0_ ( .D(din_1), .CK(clk), .RDN(rst_n), .Q(q_0) );
怎么 在单元例化名后 有一个 - 符号呢,怎么去掉呢 |
