查看: 2602|回复: 0
[求助] ICC中data_setup阶段set physopt_power_critical_range
发表于 2014-10-27 12:11:50 | 显示全部楼层 |阅读模式
set physopt_power_critical_range 一般设为多少比较好,下面是他的描述The  power  critical range specifies a margin of slack for cells during
       leakage power optimization.  If a cell has a slack less than the  power
       critical  range,  leakage  power  optimization will not be done for the
       cell.  The default value is minus infinity; that is, all cells will  be
       optimized for leakage power during the leakage power optimization phase
       of the physopt command.
GMT+8, 2025-12-19 04:27 , Processed in 0.013959 second(s), 6 queries , Gzip On, Redis On.
