查看: 2492|回复: 0
[原创] VIRTEX4_
发表于 2014-10-23 21:52:54 | 显示全部楼层 |阅读模式
STARTUP_VIRTEX4 STARTUP_VIRTEX4_inst (
      .EOS(EOS), // End Of Startup 1-bit output
      .CLK(CLK), // Clock input for start-up sequence
      .GSR(GSR_PORT), // Global Set/Reset input (GSR can not be used as a port name)
      .GTS(GTS_PORT), // Global 3-state input (GTS can not be used as a port name)
      .USRCCLKO(USRCCLKO), // USERCLK0 1-bit input
      .USRCCLKTS(USRCCLKTS), // USERCLKTS 1-bit input
      .USRDONEO(USRDONEO), // USRDONE0 1-bit input
      .USRDONETS(USRDONETS) // USRDONETS 1-bit input
这个原语怎么调用?
GMT+8, 2025-12-30 10:15 , Processed in 0.013559 second(s), 6 queries , Gzip On, Redis On.
