查看: 4326|回复: 2
[求助] Zynq PL侧逻辑敏感列表中有主时钟以外的外部信号,结果implement后报错
发表于 2014-10-22 11:38:10 | 显示全部楼层 |阅读模式
Zynq7020, PL侧逻辑中在敏感列表加入主时钟以外的外部信号,结果implement后报错,各位有没有遇到如下情况,请问如何解决,谢谢!
[Place 30-574] Poor placement for routing between an IO pin and BUFG. If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule.
< set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets AD0_SCLK_Fbk_IBUF] >
AD0_SCLK_Fbk_IBUF_inst (IBUF.O) is locked to IOB_X1Y15
and AD0_SCLK_Fbk_IBUF_BUFG_inst (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y0
发表于 2015-7-13 18:48:20 | 显示全部楼层
请问一下您这个问题解决了吗?能否告知一下是怎么解决的?谢谢
发表于 2015-7-14 09:10:07 | 显示全部楼层
GMT+8, 2025-12-15 14:05 , Processed in 0.190196 second(s), 7 queries , Gzip On, Redis On.
