查看: 6888|回复: 8
[求助] hsim如何设置子模块的精度
发表于 2014-10-10 14:40:18 | 显示全部楼层 |阅读模式
hsim仿真需要分模块设置精度,以下2种方式均为成功:1、hsim仿真文件中设置
   .param hsimspeed = 3
   .param hsimspeed = 0 subckt = vco
仿真精度全部被设置为0了
2. hsim仿真文件中设置
   网标中
   .subckt vco 端口名
   + hsimspeed = 0
   管子参数
  .ends
仿真精度全部被设置为3,VCO精度设置未成功
请教如何设置模块的精度,谢谢
 楼主| 发表于 2015-1-22 15:42:14 | 显示全部楼层
怎么没有人帮我呢
应该怎么设置模块精度呀
 楼主| 发表于 2015-1-22 17:06:29 | 显示全部楼层
.hsimpara subckt = cellname inst=instname hsimanalog = x hsimspeed=x
.hsimparam subckt=samp hsimanalog=2
is equivalent to adding “.param hsimanalog=2” statement into the subcircuit definition of
samp.
.hsimparam subckt=samp inst=X1 hsimanalog=2
is equivalent to appending “hsimanalog=2” to the end of instance X1 within the
subcircuit definition samp.
.hsimparam inst=X1 hsimanalog=2
is equivalent to appending hsimanalog=2 to the end of top level instance X1.
 楼主| 发表于 2015-1-22 17:09:30 | 显示全部楼层
samp.
发表于 2015-1-22 17:31:06 | 显示全部楼层
hsimanalog
发表于 2017-5-3 11:17:36 | 显示全部楼层
好像是需要先写局部子电路的设置,然后再写全局设置才会生效
发表于 2017-5-3 11:32:13 | 显示全部楼层
补充一下,好像得用.hsimparam来设置
发表于 2019-5-24 09:54:11 | 显示全部楼层
解决了吗?我也遇到同样的问题
发表于 2021-9-24 21:23:08 | 显示全部楼层
I use hsim sim , but  bandgap  vbg=2.5v
but hspice sim  1.1v
why whole chip sim bandgap fail  ?
use .hsimparmter  hsimanalog=3
GMT+8, 2025-12-20 04:19 , Processed in 0.025106 second(s), 6 queries , Gzip On, Redis On.
