楼主: caoshangfei
[解决] INCISIV 13.10.001 安装文件和crack破解(NCsim13.1,IES13.1 , NC-verilog13.1)
发表于 2017-5-11 07:42:48 | 显示全部楼层
Thank you very much
发表于 2017-5-11 23:45:47 | 显示全部楼层
回复 1# caoshangfei
thank you very much for sharing.I could not get it beyond iscape.sh, your first step to install
I did manage to get INCISIV_13.10.001 in my install folder:
after I click on the right button, "install from local directory or Media"
I got this:
But after I click next at the bottom, I got this "exception" error, and could not go further, Please help
发表于 2017-5-11 23:52:36 | 显示全部楼层
回复 1# caoshangfei
I downloaded all 6 files:
-rw-rw-r--.  1 dubeeloo dubeeloo   31596884 May 10 17:38 license.zip
-rw-rw-r--.  1 dubeeloo dubeeloo   85325825 May 10 17:41 bkupinstallscape.tar.bz2
-rw-rw-r--.  1 dubeeloo dubeeloo   70974074 May 10 18:11 INCISIV_13.10.zip
-rw-rw-r--.  1 dubeeloo dubeeloo  258918400 May 10 18:11 installscape.tar
-rw-rw-r--.  1 dubeeloo dubeeloo 3221225472 May 10 21:06 INCISIV_13.10.z01
-rw-rw-r--.  1 dubeeloo dubeeloo 3221225472 May 10 21:06 INCISIV_13.10.z02
and got INCISIV_13.10.001 in my install directory:
drwxrwxr-x.  4 dubeeloo dubeeloo       4096 May 10 23:55 INCISIV_13.10.001
but my install script could not run
./installscape/iscape/bin/iscape.sh
please help, those of you already installed.
发表于 2017-5-12 00:01:54 | 显示全部楼层
回复 1# caoshangfei
I did use the guide *.doc, but my iscape.sh did not bring up the classic view, as in the guide.only gave me the wizard view, see my previous post,
Is there something wrong with my computer?
I have fedora 26 installed in mine
Please help, I could not continue.
发表于 2017-5-19 09:16:10 | 显示全部楼层
回复 1# caoshangfei
I could not install the INCISIV_13.10: in your post 3:
   3.
点击图标,选择安装源文件的路径,路径在与licenseinstallscapte.tar.bz2.gz平行的INCISIV_13.10.001
4. 选择安装路径,file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image004.gif 上所有可以file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image005.gif 的选项, 然后点击对话框左下角的start
5. 安装完成之后会进行配置,根据提示一路回车或者输入y再回车即可,如果碰到license相关的按y无法通过,则按n配置过程中会有提示安
but when I select
INCISIV_13.10.001
Screenshot from 2017-05-11 08-42-13.png Screenshot from 2017-05-18 18-17-37.png
I would get the error on the right
please help
发表于 2017-5-19 12:48:19 | 显示全部楼层
回复 125# xiaoyisimonguo
I could see virtuoso with which virtuoso:
   /tools/cadence/IC06.14.005/tools/dfII/bin/virtuoso
but when I type in
virtuoso
I got
"virtuoso: Command not found."
and the virtuoso is:
lrwxrwxrwx. 1 dubeeloo dubeeloo 39 May 18 17:32 /tools/cadence/IC06.14.005/tools/dfII/bin/virtuoso -> ../../../share/bin/cdnWrapperWithOA2009
please help
发表于 2017-5-27 10:12:37 | 显示全部楼层
回复 1# caoshangfei
    谢谢~~~~~~~~~~~~~~~~~~~~~~~~~~
发表于 2017-5-27 10:28:44 | 显示全部楼层
Thanks for sharing
发表于 2017-6-15 00:14:08 | 显示全部楼层
请问楼主,[tt@localhost cadence]$ ./patch_cadence2012
./sfk: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
提示这个怎么弄啊,我是centos6.5 64位系统,我看来下我到usr/lib64里面有这个文件,但提示找不到,是什么原因啊?谢谢!
发表于 2017-6-16 10:40:38 | 显示全部楼层
好好学习
GMT+8, 2025-12-24 21:35 , Processed in 0.025550 second(s), 6 queries , Gzip On, Redis On.
