楼主: magicdog
[转]几道analog面试题
发表于 2007-6-19 10:29:51 | 显示全部楼层
无奈!没有好好看过Ra~的书籍
刚开始可能还没有真正意识到这本书的重要性吧?加油了!
发表于 2007-6-19 14:42:19 | 显示全部楼层
哇靠,看书果然有用呀~~~~~~~
发表于 2007-6-19 17:09:43 | 显示全部楼层
6 ffset
I think it means DC offset. If the opamp gain is fairly large, than a tiny offset at input will cause the output to be saturated.
And suppose it is a two stage opamp, the offset at the output of the first stage will also saturate the second stage input.
If opamp has differential output , a common mode feedback circuit is needed to provide a stable DC operation point.
发表于 2007-6-20 09:45:32 | 显示全部楼层
[quote][/quote]6. offset,对于一个普通的2-stage op-amp,有哪些offset (input diff pair,
}M)m'W"@|&`,a:{W$n-u;j;Qoutput of the 1st stage, etc),在这些offset中,哪些是有major影响的,它们各自
2_eFW;Twww.eetop.cn的影响分别是什么?
谢谢上楼的回答,但在这些offset中那些是主要的影响,每一种offset怎么解决呀?谢谢!
发表于 2007-6-21 12:42:54 | 显示全部楼层
请问一下这是本科生还是研究生的面试题目呀?
发表于 2007-6-21 21:22:19 | 显示全部楼层
好帖啊,谢谢楼主!!!
 楼主| 发表于 2007-6-22 08:56:52 | 显示全部楼层
offset 主要来自2个方面
1, "system offset" The current source is not a ideal source. It's inner resister is not infinite!!
2, offset from matching 取决于layout了
发表于 2007-6-22 09:51:59 | 显示全部楼层
I see, Thank you!
发表于 2007-6-23 10:29:32 | 显示全部楼层
提不是很难
发表于 2007-7-15 10:41:50 | 显示全部楼层
还好知道一点
GMT+8, 2025-12-29 10:09 , Processed in 0.018142 second(s), 5 queries , Gzip On, Redis On.
