查看: 3155|回复: 0
[求助] 請問有類似 Variant Assembly的工具嗎?
发表于 2014-9-8 08:15:16 | 显示全部楼层 |阅读模式
最近看到一個這樣的工具
http://www.flowcad.com/FloWare-Variant-Assembly.htm
                Documentation of Variants        Some customers have more requirements to document assembly information which are exceeding the possibilities of PCB Editor. With FloWare Variant Assembly the assembly prints can be designed by individual needs.The content of the assembly drawings can be customized (i.e. RefDes, PartNumber, Tolerance or Value) and printed into geometric objects like Assembly, DFA_Bound, Display, Place_Bound or Silkscreen.
Parts which will not be assembled in a variant can be indicated by crossing out the symbol or its text or by removing values or text from the drawing (Draw Cross Graphics, Draw Cross Label, Remove Label or Remove all).
Label text can be modified with prefix or suffix. Symbols can be hached for better readibility. Symbols can be colored not only by variant, but also for special parts (i.e. highlight all 0402 parts in blue), when special manufacturing handling is required.
GMT+8, 2025-12-24 09:02 , Processed in 0.012106 second(s), 4 queries , Gzip On, Redis On.
