查看: 2401|回复: 1
[求助] mim capacitor
发表于 2014-8-29 10:21:06 | 显示全部楼层 |阅读模式
Hi guys,
       one question for mim capacitor. usually, the metal of bot plate of mim is connected to top  metal, i.e. umc0.18 1p6m(metal 6  is top plate and metal  5 is bot plate).But if the bot plate is directly connected by  metal 5. what will be the problem//
发表于 2014-9-1 20:08:18 | 显示全部楼层
.18 工藝應該沒用到 copper wire.
如果只要絕對值, 通常是可以的. ( loop filter ... etc.)
如果要求 matching , 就不行.  建議問 UMC 的 CE 更清楚.
GMT+8, 2025-12-22 04:45 , Processed in 0.019580 second(s), 6 queries , Gzip On, Redis On.
