查看: 2559|回复: 3
[求助] 请教一个LVS的问题
发表于 2014-8-22 16:15:39 | 显示全部楼层 |阅读模式
各位大侠,小弟在做LVS的时候遇到了一个很奇怪的问题。网表里面的一个D触发器,foundry给的标准单元里的core cell 网表是没有二极管的,但是这个触发器的GDS文件显示有两个寄生的二极管,这样在做LVS的时候就说我的source网表里缺少二极管,请问这个问题怎么解决。还是我哪里弄错了,下面是LVS的report
  Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         QDFFRBN
SOURCE CELL NAME:         QDFFRBN
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              6         6
Nets:              17        17
Instances:         14        14         MN (4 pins)
                    14        14         MP (4 pins)
                     2         0    *    D (2 pins)
Total Inst:        30        28
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              6         6
Nets:              15        15
Instances:          4         4         MN (4 pins)
                     4         4         MP (4 pins)
                     2         0    *    D (2 pins)
                     6         6         INV (2 pins)
                     2         2         NAND2 (3 pins)
Total Inst:        18        16
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                 INCORRECT INSTANCES
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    D0(0.880,1.980)  D(DION_EE2_UCFNLL)                       ** missing instance **
         pos: GND:G                                                ** GND **
         neg: D:ID                                                 ** D **
  2    D1(1.190,1.100)  D(DION_EE2_UCFNLL)                       ** missing instance **
         neg: CK:ID                                                ** CK **
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               6          6            0            0
   Nets:               15         15            0            0
   Instances:           4          4            0            0    MN(N_18_EE2_UCFNLL)
                        4          4            0            0    MP(P_18_EE2_UCFNLL)
                        0          0            2            0    D(DION_EE2_UCFNLL)
                        6          6            0            0    INV
                        2          2            0            0    NAND2
   Total Inst:         16         16            2            0
o Layout Names That Are Missing In The Source:
   Ports:        VCC GND:G D:ID CK:ID RB:I Q:O
   Nets:         VCC GND:G D:ID CK:ID RB:I Q:O
发表于 2014-8-22 21:54:49 | 显示全部楼层
估计是增加的防天线效应的二极管。
 楼主| 发表于 2014-8-23 12:49:05 | 显示全部楼层
回复 2# Hyacinth1292
但是这个二极管是这个D触发器单元内部的二极管,foundry提供的core cell 网表的这个D触发器网表里面没有这个二极管
发表于 2014-8-24 15:24:51 | 显示全部楼层
runset里面可以打开了抽取parasitic diode的选项,看看
GMT+8, 2025-12-13 06:50 , Processed in 0.016410 second(s), 6 queries , Gzip On, Redis On.
