第一段程序LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY pwmgen IS
generic
f_len:natural:=9;
delay_len:natural:=9;
dead:natural:=5
port(
rst,clk:in std_logic;
feedin:in std_logic;
di:in std_logic;
--delay:in std_logic_vector(f_len-1 downto 0);
pwm1,pwm3,pwm2,pwm4 ut std_logic
end entity pwmgen ;
architecture bhv of pwmgen is
signal tm,pwm10,pwm20,pwm30,pwm40:std_logic;
signal delay_r:std_logic_vector(delay_len+f_len-1 downto 0);
signal cmp,cmp_dead:std_logic_vector(f_len-1 downto 0);
signal f,fi:std_logic_vector(f_len-1 downto 0);
signal delay:std_logic_vector(f_len-1 downto 0):="011001100";
signal feedcount:std_logic_vector(11 downto 0):="000000000000";
signal close:std_logic:='0';
signal dis: std_logic;
component fcounter
generic
f_len:natural:=9;
f_delta:natural:=10
port(
rst,clk,di:in std_logic;
f,fi ut std_logic_vector(f_len-1 downto 0);
tm ut std_logic
end component;
begin
d1:process(clk,close)
begin
if close='0' then
if clk'event and clk='1' then
if feedcount<"111111111100" then
feedcount<=feedcount+'1';
dis<=di;
-- di1<=dis;
else
close<='1';
dis<=feedin;
di1<=dis;
end if;
end if;
else
dis<=feedin;
di1<=dis;
end if;
end process;
fc1:fcounter generic map(9,10) port map(rst,clk,dis,f,fi,tm);
delay_r<=delay*f;
cmp<=delay_r(delay_len+f_len-1 downto delay_len);
cmp_dead<="0"&f(f'length-1 downto 1)-dead;
--adad
d:process(clk,rst)
begin
if rst='0' then
pwm10<='0';
pwm20<='0';
pwm30<='0';
pwm40<='0';
elsif clk'event and clk='1' then
if (fi>=0 and fi<cmp ) then
if tm='1' then pwm10<='1';end if;
if tm='0' then pwm20<='1';end if;
else
pwm10<='0';
pwm20<='0';
end if;
if (fi>dead and fi<cmp_dead) then
if tm='1' then pwm30<='1';end if;
if tm='0' then pwm40<='1';end if;
else
pwm30<='0';
pwm40<='0';
end if;
end if;
end process;
pwm1<=pwm10 and pwm30;
pwm3<=pwm20 and pwm40;
pwm2<=not dis;
pwm4<=dis;
end bhv; |
