查看: 3265|回复: 1
[求助] IC615 Spectre使用问题
发表于 2014-8-18 16:53:03 | 显示全部楼层 |阅读模式
IC615和MMSIM12安装好后运行Spectre报错Job.log显示“errors encountered during simulation. the simulator run log has not been generated. Possible cause could be an invalid command line option for the version of the simulator you are running. choose setup ->environment and verify that the command line option specified in
the userCmdLineOption field are supported for the simulator. Alternatively run the simulator standalone using the runSimulation file in the netlist directory to know the exact cause of the error."之后在netlist下./runSimulation显示:error while loading shared libraries: libabv.so:cannot open shared object file: No such file or directory
再在终端下输入yum whatprovides */libabv.so
显示 No Matches found.
请问大神如何解决。
发表于 2014-8-18 22:15:49 | 显示全部楼层
没遇到过。。电路都对吗?
GMT+8, 2025-11-18 20:13 , Processed in 0.018675 second(s), 6 queries , Gzip On, Redis On.
