查看: 2686|回复: 3
[招聘] NO.220-Principal/Senior Engineer of Analog PHY or SerDes IC Design(Shanghai)
发表于 2014-8-7 13:27:39 | 显示全部楼层 |阅读模式
Job Description:
1.Responsible for the design and development of PHY or SerDes analog/mixed signal IC circuit blocks from initial concept and specification through final verification and conformance to customer requirements.
2.Candidate’s background should demonstrate good problem solving skills, excellent analog aptitude, good communication skills, and ability to work cooperatively in a team environment.
3.Must have demonstrated experience in analog PHY or SerDes transceiver designs including some of the following circuit blocks: System level modeling by matlab, C, or VerilogA; Driver; Receiver; Serializer; Deserializer; Phase Interpolator; Low jitter PLL; High Speed Clock Distribution; Bias and Bandgap; Voltage Regulators.
4.Candidate should have working knowledge of a set of common SerDes standards and their electrical requirements, and a thorough understanding of jitter.
5.Position requires proficiency in using CAD tools for circuit simulation, layout, and physical verification (Cadence tool experience, lab test experience, and experience at 40nm and below technologies are a plus).
Position Requirements:
☞ Master qualifed industry experience for at least 10 years & performed core role in this field.
1.Master or PHD (prefer) degree, major in Micro-Electronics, Electronic Engineering or equivalent
2.Ability to work effectively alone or as well as in a team.
3.Essential that the individual demonstrates strong communication, verbal and written
4.Requires good communication skills in English.
5.Industry Experience for at least 8 years or more for analogy PHY or SerDes and High Speed silicon mass products
Desirable Qualifications:
☞ Analog PHY means both SerDes(for connecting one-connect) & HDMI PHY, DP (Display port) PHY solutions.
1.Knowledge of one of key SerDes Analog IC design areas and their architectures/applications:
2.Clock Data Recovery; PLL's; Oscillators; Low Noise Design; RF IC building blocks
3.Solid understanding of IC design technology and process/methodology in IC design solutions
4.Familiar with Cadence analog and mixed-signal EDA tools is a plus
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
发表于 2014-8-7 16:31:02 | 显示全部楼层
不错的职位,哪家公司的?
发表于 2014-12-11 20:13:16 | 显示全部楼层
Reply 1 # kthr
    lookinmyselfforjob
发表于 2015-7-2 13:00:55 | 显示全部楼层
哈哈哈哈哈哈很好
GMT+8, 2025-12-28 05:40 , Processed in 0.031662 second(s), 6 queries , Gzip On, Redis On.
