查看: 2908|回复: 2
[求助] 关于init_assign_buffer{1}的理解
发表于 2014-8-1 20:46:43 | 显示全部楼层 |阅读模式
cmd:解释是Specifies settings equivalent to the setDoAssign command to control whether or not assign
statements are replaced with buffers.
This setting leaves the netlist unchanged during data import, and allows EDI System applications to replace Assign nets with buffers automatically.导入的时候 网表不作任何的变动,允许用buffer自动分配net。
这里自动用buffer分配net用来干嘛的?
发表于 2014-8-2 16:42:01 | 显示全部楼层
就是把netlist中的assign替换成buffer
 楼主| 发表于 2014-8-3 13:39:02 | 显示全部楼层
回复 2# teamwork8
    替换不替换的区别是?assigne本来在netlist是指什么
GMT+8, 2025-12-24 21:23 , Processed in 0.016664 second(s), 9 queries , Gzip On, Redis On.
