楼主: 3008202060
[求助] 管脚分配出现的问题
发表于 2014-9-7 10:48:35 | 显示全部楼层
回复 管脚分配出现的问题
改为红色部分就好了
改为红色部分就好了
发表于 2014-9-7 14:26:03 | 显示全部楼层
Do you used design partation function of Quaruts software? If your partation was used post-fitting netlist, it can't change the matche pin assignment.
发表于 2014-10-29 10:37:39 | 显示全部楼层
回复 12# zhangbinsniper
   我也遇到这样的问题,根据你的回复,顺利解决,多谢!
GMT+8, 2025-12-15 22:21 , Processed in 0.014547 second(s), 6 queries , Gzip On, Redis On.
