查看: 3785|回复: 7
[求助] 求助 : VCO设计中如果用电阻代替电流源会有什么好处和坏处呢?
发表于 2014-7-30 15:08:23 | 显示全部楼层 |阅读模式
如题~想请教一下 VCO设计中如果用电阻代替电流源会有什么好处和坏处呢~
发表于 2014-7-30 22:46:46 | 显示全部楼层
都很明显
避免1/f up conversion
amplitude 需要calibration 去锁
发表于 2014-7-31 00:27:05 | 显示全部楼层
TAIL Current-based LCVCO has a better PVT since its bias current is well-defined. For most of cases, even removing the tail is better than replacing it with a res.
Ham's design procedure for minimum phase noise:
1. set a Imax=Itail (power consideration)
2. find the Lmin that could start the VCO and provides a swing enough for next stage, i.e., divider or something capacitive.
发表于 2014-7-31 08:43:19 | 显示全部楼层
工艺偏差,噪声,面积,蒙特卡洛分析,等等。。。
 楼主| 发表于 2014-7-31 08:49:12 | 显示全部楼层
回复 3# onepieceligen
   THX VERY MUCH!!!
 楼主| 发表于 2014-7-31 08:49:51 | 显示全部楼层
回复 2# daxigua179
   嗯~非常感谢~
发表于 2014-7-31 09:41:08 | 显示全部楼层
回复 2# daxigua179
   1/f noise from tail is AM noise, so just being careful of the AM-TO-PM noise conversion by Varactors can almost eliminate it. I think tail is better than res, but a no-tail high-swing NPMOS 4T VCO is even better in low-voltage design.
发表于 2024-5-8 10:36:34 | 显示全部楼层
daxigua179 发表于 2014-7-30 22:46
都很明显
避免1/f up conversion
amplitude 需要calibration 去锁。请教一下,(1)原因是啥?尾电流的是怕尾电流管进入线性区,但电阻没这一说(2)有calibration文章推荐?感谢
GMT+8, 2025-10-21 05:27 , Processed in 0.022242 second(s), 4 queries , Gzip On, Redis On.
