楼主: stephenia
[原创] charge pump
 楼主| 发表于 2014-7-31 11:03:35 | 显示全部楼层
回复 10# frankobvip
这是一篇论文中的电路,第一级NMOS,衬底接地,之后的都是PMOS,电路能够正常工作,但貌似只能低压应用啊。。。
发表于 2014-8-1 10:12:58 | 显示全部楼层
回复 11# stephenia
   2006 JSSC design of charge pump circuit with consideration of gate-Oxide reliability in low voltage cmos processes你可以参考下
 楼主| 发表于 2014-8-1 11:01:39 | 显示全部楼层
回复 12# frankobvip
谢谢!
发表于 2016-4-3 12:37:03 | 显示全部楼层
楼主,你这个怎么会产生负电压呢?还有你这个cross-couple charge pump后面为什么只有pmos?
发表于 2016-12-30 15:41:24 | 显示全部楼层
电路结构特别是body连接错误,请参考《Design of Charge Pump Circuit With Consideration of Gate-Oxide Reliability in Low-Voltage CMOS Processes》及《A low-voltage charge pump with wide current driving capability》
GMT+8, 2025-12-19 11:32 , Processed in 0.013775 second(s), 3 queries , Gzip On, Redis On.
