查看: 4092|回复: 8
[资料] Op Amps for Everyone: Design Reference 第二版
发表于 2014-7-16 16:14:23 | 显示全部楼层 |阅读模式
亚马逊地址:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Op+Amps+for+Everyone%3A+Design+Reference%2C+Second+Edition
介绍:
ook Description[size=0.86em]Publication Date: April 29, 2003 | ISBN-10: 0750677015 | ISBN-13: 978-0750677011 | Edition: 2
The operational amplifier ("op amp") is the most versatile and widely used type of analog IC, used in audio and voltage amplifiers, signal conditioners, signal converters, oscillators, and analog computing systems. Almost every electronic device uses at least one op amp. This book is Texas Instruments' complete professional-level tutorial and reference to operational amplifier theory and applications. Among the topics covered are basic op amp physics (including reviews of current and voltage division, Thevenin's theorem, and transistor models), idealized op amp operation and configuration, feedback theory and methods, single and dual supply operation, understanding op amp parameters, minimizing noise in op amp circuits, and practical applications such as instrumentation amplifiers, signal conditioning, oscillators, active filters, load and level conversions, and analog computing. There is also extensive coverage of circuit construction techniques, including circuit board design, grounding, input and output isolation, using decoupling capacitors, and frequency characteristics of passive components. The material in this book is applicable to all op amp ICs from all manufacturers, not just TI. Unlike textbook treatments of op amp theory that tend to focus on idealized op amp models and configuration, this title uses idealized models only when necessary to explain op amp theory. The bulk of this book is on real-world op amps and their applications; considerations such as thermal effects, circuit noise, circuit buffering, selection of appropriate op amps for a given application, and unexpected effects in passive components are all
discussed in detail.
[Ron_Mancini]_Op_Amps_for Everyone Design Reference.part1.rar (14.31 MB , 下载次数: 324 )
[Ron_Mancini]_Op_Amps_for Everyone Design Reference.part2.rar (3.18 MB , 下载次数: 188 )
发表于 2014-7-17 12:37:24 | 显示全部楼层
一份比较实用的PCB电磁兼容方面的资料
发表于 2014-7-17 20:37:21 | 显示全部楼层
kan kan ru he
发表于 2014-7-18 09:07:08 | 显示全部楼层
感谢楼主分享
发表于 2014-7-22 09:17:26 | 显示全部楼层
这本书已经出到第四版,作者已经过度到Bruce Carter了。
发表于 2015-5-30 12:28:47 | 显示全部楼层
感谢楼主分享
发表于 2015-11-8 11:56:45 | 显示全部楼层
回复 5# 过路心客
    请问第四版和第三版有什么区别?
发表于 2018-9-2 01:01:35 | 显示全部楼层
THANK YOU
发表于 2020-4-4 20:48:59 | 显示全部楼层
thanks
GMT+8, 2025-12-19 04:36 , Processed in 0.024005 second(s), 7 queries , Gzip On, Redis On.
