查看: 2243|回复: 0
[讨论] cadence仿真遇到的问题
发表于 2014-7-11 10:39:39 | 显示全部楼层 |阅读模式
电路有A/B/C/D.....多个模块构成,每个模块上都有输出总线,直接在该电路图上搭建仿真环境进行仿真没有遇到问题。但是,将该电路建成symbol后(即A/B/C/D。。。等输出小总线,第二次又合并成大总线),再进行仿真总是提示:
error**the memory request exceeds the current available space.
#memory which has been allocated = 3911150kbyte
#memory in next memory request which fails = 131kbyte
please continue by
step 1:inspect input file for possible errors in .TRAN
          statement or any sources with repeating functions.
step 2:if other users or jobs are running , wait until they free up more memory space.
step e:have your system manager enlarge the swap space on this cpu.
******job aborted.
看到有以前的项目中也由这样子标记的结构,,是不是这样子标记后,cadence仿真计算方式发生了很多重复,从而导致计算次数比非symbol
时多了很多,因此提示空间不足呀。。symbol后仿真电路check的时候没有问题。。
有了解原因的前辈吗?该怎么解决呢??
GMT+8, 2025-12-19 13:21 , Processed in 0.018207 second(s), 5 queries , Gzip On, Redis On.
