楼主: min4max
Cadence IC616等套件以及Calibre2013的正规设置及使用,另附Jake Baker的教科书
 楼主| 发表于 2014-11-20 23:06:18 | 显示全部楼层
    Totally wrong and outdated features for PVS141!!!  Obviously you haven't read the PVS141 User Guide in the PVS_install_dir/doc/pvsuser/pvsuser.pdf to find out what license features required for the PVS141.  Here're the partial new features in the license file for most PVS functions to run:
FEATURE Phys_Ver_Sys_Const_Validator cdslmd 1000.000 permanent uncounted HOSTID=ANY \
    SIGN2="0868 93A0 143D 70B3 CB2E D1E6 4076 D793 656C C7FB 4675 C52D DD2C 1871 \
    E621 082C 09F7 EAA4 092F 6119 FEBF 20A5 AC61 96B9 20BD 834A 6000 263A 43D1 5D5E"
FEATURE Phys_Ver_Sys_DRC_XL cdslmd 1000.000 permanent uncounted HOSTID=ANY \
    SIGN2="1626 AFBC 787E A863 8E60 608B 6D98 CF1C F62F E33F 814B 64D2 CBFE 2FB7 \
    B3AA 0098 179F FE18 FAC1 DDF1 FC43 EA0F 7E1A 7003 914E 3CB2 0727 39E7 5EB6 045C"
FEATURE Phys_Ver_Sys_Graph_LVS_Debug cdslmd 1000.000 permanent uncounted HOSTID=ANY \
    SIGN2="16E5 0C22 1991 CAB3 87E6 43AB C23F 3683 0A10 486E AAA6 3CF4 DB1B A150 5585 \
    0947 647F 8169 79D6 BA18 E765 D536 FCD2 4E9E B453 31E0 6204 F5D6 9689 1FA8"
FEATURE Phys_Ver_Sys_LVS_XL cdslmd 1000.000 permanent uncounted HOSTID=ANY \
    SIGN2="046F BE86 A0CE 3753 15D2 D686 3ACF 9B4A C808 CB51 692C 3E71 75DC 9269 \
    6D94 0D84 CDFA 07BD FD87 8025 E1BD 5F44 AE1D 91FB 48AC 6C46 4607 B8BA 20D6 988A"
FEATURE Phys_Ver_Sys_Results_Mgr cdslmd 1000.000 permanent uncounted HOSTID=ANY \
    SIGN2="1C85 4F28 D7CF FA1D EF1C DF80 8635 A2D4 7078 B90A 139B 1983 76C8 3C41 \
    346A 17AF C782 7F92 E0A7 D43F 5FC1 DAFD C7FD 8369 3B83 50A2 6CF5 DD7B 6D84 2BC1"
The patch file in my post at #1 is correct one to patch all new Cadence products.
There're a few other new features for additional PVS141 functions to run correctly.  Here're the list:
Phys_Ver_Sys_Adv_Ana_Opt
Phys_Ver_Sys_Adv_Device
Phys_Ver_Sys_Design_Ana
Phys_Ver_Sys_Pattern_Match
Phys_Ver_Sys_Prog_ERC
among which Phys_Ver_Sys_Prog_ERC is required to run PERC.  You have to find out a solution to make the encription SIGN2 for each of these features.  The EFA licgen 0.4b tool found in the EETOP forums doesn't work for IC61x and other newer version of Cadence products.  It doesn't create SIGN2 encription necessary for the newer Cadence products.  Maybe this article might help you on the subject: http://bbs.pediy.com/showthread.php?t=152615
发表于 2014-11-21 15:59:50 | 显示全部楼层
I know that after after version 10 the PVS license scheme is changed and old licenses are not valid. That is why I was asking for new ones and the appropriate patch.
I tried the license features which you've posted but the license service is failing.
It seems that they could not with flexlm v10.8.0.7
9:34:52 (cdslmd) FLEXnet Licensing version v10.8.0.7 build 26147
9:34:52 (lmgrd) Started cdslmd (internet tcp_port 58270 pid 3705)
9:34:54 (cdslmd) Invalid license key (inconsistent authentication code)
9:34:54 (cdslmd)       ==>FEATURE Phys_Ver_Sys_Const_Validator cdslmd 1000.000 permanent \
        uncounted HOSTID=ANY SIGN2="0868 93A0 143D 70B3 CB2E D1E6 4076 \
        D793 656C C7FB 4675 C52D DD2C 1871 E621 082C 09F7 EAA4 092F \
9:34:54 (cdslmd)       ==>FEATURE Phys_Ver_Sys_DRC_XL cdslmd 1000.000 permanent uncounted \
        HOSTID=ANY SIGN2="1626 AFBC 787E A863 8E60 608B 6D98 CF1C F62F \
        E33F 814B 64D2 CBFE 2FB7 B3AA 0098 179F FE18 FAC1 DDF1 FC43 \
9:34:54 (cdslmd)       ==>FEATURE Phys_Ver_Sys_Graph_LVS_Debug cdslmd 1000.000 permanent \
        uncounted HOSTID=ANY SIGN2="16E5 0C22 1991 CAB3 87E6 43AB C23F \
        3683 0A10 486E AAA6 3CF4 DB1B A150 5585 0947 647F 8169 79D6 \
9:34:54 (cdslmd)       ==>FEATURE Phys_Ver_Sys_LVS_XL cdslmd 1000.000 permanent uncounted \
        HOSTID=ANY SIGN2="046F BE86 A0CE 3753 15D2 D686 3ACF 9B4A C808 \
        CB51 692C 3E71 75DC 9269 6D94 0D84 CDFA 07BD FD87 8025 E1BD \
9:34:54 (cdslmd)       ==>FEATURE Phys_Ver_Sys_Results_Mgr cdslmd 1000.000 permanent uncounted \
        HOSTID=ANY SIGN2="1C85 4F28 D7CF FA1D EF1C DF80 8635 A2D4 7078 \
        B90A 139B 1983 76C8 3C41 346A 17AF C782 7F92 E0A7 D43F 5FC1 \
发表于 2014-11-21 16:03:45 | 显示全部楼层
Actually I knew that there is a new license scheme for PVS versions above 10, that is why i was looking for appropriate license file and patch for PVS.
I tried the license feature which you've posted but it seems they do not start with flexlm v10.8.0.7
发表于 2014-11-21 19:01:50 | 显示全部楼层
回复 1# min4max
   楼主你好!看你帖子calibre最后集成到了layout菜单里面。我用5141的时候也是这样没问题,但是615下装完了【可以用calibre -gui打开】却没集成上去,请问你知道是什么原因吗?菜单里能看到verify,里面有DRC和LVS等,但是明显不像calibre的东西呀。多谢多谢!
 楼主| 发表于 2014-11-21 21:45:20 | 显示全部楼层
I know that after after version 10 the PVS license scheme is changed and old licenses are not valid. ...
Jsanchez12345 发表于 2014-11-21 15:59
    Oh, again!  Why do you start up license server???  I've reiterated many times once all license FEATUREs are set to uncounted (that's unlimited use!!!) in the FEATURE line, you NEVER ever need to start up Flexlm license server!!!  And you have to remove SERVER and DAEMON lines from the license.dat file, that is, the license.dat here is a pure FEATURE file without any other lines!  That's the way Flexlm server/license runs.
 楼主| 发表于 2014-11-21 22:59:54 | 显示全部楼层
回复  min4max
   楼主你好!看你帖子calibre最后集成到了layout菜单里面。我用5141的时候也是这样没 ...
gmrk 发表于 2014-11-21 19:01
    Virtuoso菜单里的Verify与Calibre无关,甚至与Cadence本身的Assura都无关。那是老式的Diva。我在正文中已经说了,你需要将那个Mentor官方说明文件中有关部分拷贝到将要运行Cadence的那个目录中的.cdsinit文件中(这是个隐藏文件,需要将目录设成显示隐藏文件
Alt+),然后再设置环境变量。详细参见Caliber2014的设置说明教程及其后面的各个回复:http://bbs.eetop.cn/thread-463453-1-1.html
发表于 2014-11-22 09:53:44 | 显示全部楼层
回复 126# min4max
   哦,感谢感谢!是我没有把你的讲解看清楚,现在已经都OK啦!
发表于 2014-11-22 10:47:03 | 显示全部楼层
回复 1# min4max
   楼主你好,本人小白,安装好之后,发现configure的状态是failed。对于“需要注意的是在configure设置各个Cadence软件(IC,MMSIM,Assura,...)阶段时你需要将所有Cadence软件的oa指向IC内的oa目录,比如说/opt/cadence/IC616/oa_v22.43.018”该如何手动操作?谢谢楼主!
发表于 2014-11-22 16:23:37 | 显示全部楼层
我大三有一个学期在自己摸索Cadence,synopsys,mentor等软件在笔记本上的安装和配置,也为此装了很多Linux系统,过程痛苦,可能就是觉得好玩吧,看到楼主这篇文章,我有起了兴趣,考完研后寒假在家继续玩一玩,试试最新的软件版本看。
发表于 2014-11-22 19:15:53 | 显示全部楼层
哥们,你为中国IC 行业做出了贡献!!!
GMT+8, 2025-10-30 05:57 , Processed in 0.018842 second(s), 3 queries , Gzip On, Redis On.
