查看: 4510|回复: 5
[求助] The target_library does not contain an inverter的ERROR
发表于 2014-7-3 17:06:36 | 显示全部楼层 |阅读模式
菜鸟请教,在做ICC时遇到如下问题
首先,target_library我只定义了ss库,
然后通过set_min_library设置了ss(max)和ff(min)的库,
再然后,我设置operating_condition时依据上面的ss和ff设置了min和max condition。
....place_opt 报错如下
Error: The target_library does not contain an inverter characterized for operating condition (voltage = 5.00000V, process = 1.000000, temperature = 125.000000). (MV-006)
This problem occurred at:
    <top design>
Error: The target library does not contain an inverter.
        An inverter is required for mapping. (OPT-101)
0
请大侠指教,多谢。
发表于 2014-7-3 18:10:43 | 显示全部楼层
那就先别set_min_library , 单独跑ss 看看
 楼主| 发表于 2014-7-9 09:26:45 | 显示全部楼层
我试过了,还是报原来的错误!
发表于 2014-7-9 15:00:52 | 显示全部楼层
不设operating condition行么, 一套库设不设都一样的,
发表于 2014-7-11 09:44:23 | 显示全部楼层
以前遇到过类似是因为dont touch dont use定义的有问题,你看看库里是不是inv都dont use了
发表于 2023-10-13 15:07:16 | 显示全部楼层
楼主解决了吗
GMT+8, 2025-12-19 23:40 , Processed in 0.020613 second(s), 4 queries , Gzip On, Redis On.
