查看: 3010|回复: 9
[求职] Power Analog design with 10y experiences
发表于 2014-6-26 20:54:55 | 显示全部楼层 |阅读模式
Specialities
1,  Low voltage DC/DC including Charge pump and Li-ion battery charger systematical design and topology buildup;
2,  Low EMI, low noise power supply including Bandgap, DC/DC, and LED driver;
3,  Consumer field power supply insight and overview including cell phone;
4,  Power and signal integrity including process silicon and device physics knowledges, also tackle SSN and Ldi/dt noise;
5,  PMT (power management techniques) including ‘Clock and Power Gating’, MSV, PSO, DVS, DVFS and AVFS as compared to PMU (power management unit)  professionalism;
6,  PVT (process, voltage and temperature) sensor techniques;
7,  BMS (battery management system) knowledges;
8,  High matching and accuracy LED driver;
9,  High matching, low offset and high safety layout and P&R techniques;
10,  Mix-signal knowledges;
11, All-around failure prevention techniques;
12, Digital VLSI design flow from verilog to silicon;
发表于 2014-6-27 10:39:14 | 显示全部楼层
此帖仅作者可见
发表于 2014-6-27 10:41:35 | 显示全部楼层
此帖仅作者可见
发表于 2014-6-30 10:49:16 | 显示全部楼层
此帖仅作者可见
发表于 2014-6-30 11:12:15 | 显示全部楼层
此帖仅作者可见
发表于 2014-6-30 18:25:40 | 显示全部楼层
此帖仅作者可见
发表于 2014-7-14 16:14:40 | 显示全部楼层
此帖仅作者可见
发表于 2014-7-15 20:40:38 | 显示全部楼层
此帖仅作者可见
发表于 2014-7-17 12:52:20 | 显示全部楼层
此帖仅作者可见
发表于 2014-7-29 15:57:42 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-11-10 11:24 , Processed in 0.026648 second(s), 5 queries , Gzip On, Redis On.
