查看: 2794|回复: 0
[求助] 请教一个关于彩灯程序的问题
发表于 2014-6-24 13:26:41 | 显示全部楼层 |阅读模式
最近在做一个设计,题目是这样的:设计一个多路彩灯控制器,能够在四种不同的彩灯花样之间进行循环变化,并可设置花型变化的节奏,且可进行复位。然后我设计完程序之后,编译通过,下载在Cyclone的EP1C12Q240C8上能百分百下载成功,但是没有实验现象,即板上的灯都是暗的,请教各位大神这是什么原因,源程序如下:
时序控制电路的VHDL源程序
--SXKZ.VHD
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY SXKZ IS
PORT(CHOSE_KEY:IN STD_LOGIC;
CLK_IN:IN STD_LOGIC;
CLR:IN STD_LOGIC;
CLK:OUT STD_LOGIC);
END ENTITY SXKZ;
ARCHITECTURE ART OF SXKZ IS
SIGNAL CLLK:STD_LOGIC;
BEGIN
PROCESS(CLK_IN,CLR,CHOSE_KEY)IS
VARIABLE TEMP:STD_LOGIC_VECTOR(2 DOWNTO 0);
BEGIN
IF CLR='1' THEN
——当CLR等于‘1’时清零,否则正常工作
CLLK<='0';TEMP:="000";
ELSIF RISING_EDGE(CLK_IN)THEN
IF CHOSE_KEY='1' THEN
IF TEMP="011" THEN
TEMP:="000";
CLLK<=NOT CLLK;
ELSE
TEMP:=TEMP+'1';
END IF;
——当CHOSE_KEY=1’时产生基准时钟频率的1/4的时钟信号
——否则产生基准时钟频率的1/8的时钟信号
ELSE
IF TEMP="111"THEN
TEMP:="000";
CLLK<=NOT CLLK;
ELSE
TEMP:=TEMP+'1';
END IF;
END IF;
END IF;
END PROCESS;
END ARCHITECTURE ART;
显示控制电路的VHDL源程序
--XSKZ.VHD
LIBRARY IEEE;
ENTITY XSKZ IS
PORT(CLK:IN STD_LOGIC;
CLR:IN STD_LOGIC;
LED:OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
END ENTITY XSKZ;
ARCHITECTURE ART OF XSKZ IS
TYPE STATE IS(S0,S1,S2,S3,S4);
SIGNAL CURRENT_STATE:STATE;
SIGNAL FLOWER:STD_LOGIC_VECTOR(7 DOWNTO 0);
BEGIN
PROCESS(CLR,CLK)IS
CONSTANT F1:STD_LOGIC_VECTOR(7 DOWNTO 0):="01010101";
CONSTANT F2:STD_LOGIC_VECTOR(7 DOWNTO 0):="10101010";
CONSTANT F3:STD_LOGIC_VECTOR(7 DOWNTO 0):="10011001";
CONSTANT F4:STD_LOGIC_VECTOR(7 DOWNTO 0):="01100110";
——四种花型定义
BEGIN
IF CLR='1'THEN
CURRENT_STATE<=S0;
ELSIF RISING_EDGE(CLK)THEN
CASE CURRENT_STATE IS
WHEN S0=>
FLOWER<="ZZZZZZZZ";
CURRENT_STATE<=S1;
WHEN S1=>
FLOWER<=F1;
CURRENT_STATE<=S2;
WHEN S2=>
FLOWER<=F2;
CURRENT_STATE<=S3;
WHEN S3=>
FLOWER<=F3;
CURRENT_STATE<=S1;
WHEN OTHERS=>
FLOWER<=F1;
CURRENT_STATE<=S1;
END CASE;
END IF;
END PROCESS;
LED<=FLOWER;
顶层文件
--CDKZQ.VHD
LIBRARY IEEE;
ENTITY CDKZQ IS
PORT(CLK_IN:IN STD_LOGIC;
CLR:IN STD_LOGIC;
END ENTITY CDKZQ;
ARCHITECTURE ART OF CDKZQ IS
COMPONENT SXKZ IS
CLR:IN STD_LOGIC;
CLK:OUT STD_LOGIC);
END COMPONENT SXKZ;
COMPONENT XSKZ IS
CLR:IN STD_LOGIC;
END COMPONENT XSKZ;
SIGNAL S1:STD_LOGIC;
BEGIN
U1:SXKZ PORT MAP(CHOSE_KEY,CLK_IN,CLR,S1);
U2:XSKZ PORT MAP(S1,CLR,LED);
不知道我的程序有没有写错,请大神不吝指正,万分感谢!
GMT+8, 2025-12-14 17:42 , Processed in 0.019303 second(s), 6 queries , Gzip On, Redis On.
