楼主: guangyuan.lam
level shifter paper (cont)
头像被屏蔽
发表于 2008-8-7 09:10:03 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-8-7 09:19:47 | 显示全部楼层
谁写的???
柯明dao
头像被屏蔽
发表于 2008-9-20 16:00:25 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-9-28 23:31:03 | 显示全部楼层
好像有过了
发表于 2009-2-11 14:53:47 | 显示全部楼层
無限感激你得資料
发表于 2010-9-20 15:10:31 | 显示全部楼层
THANKS A LOT
发表于 2010-9-20 15:47:21 | 显示全部楼层
不错,谢谢
发表于 2010-10-2 20:45:07 | 显示全部楼层
This paper presents design and application of a
level shifter circuit which works with a single power
supply. Unlike the conventional level shifter circuits,
the proposed level shifter can shift any voltage level
signal to a desired higher level without any leakage
current. Use of single supply level shifter greatly
reduces the supply routing and layout congestion
within the chip when level shifting is required between
different voltage domains. It also reduces pin count if
level shifting is required between two or more chips
operating at different supply voltages in a multivoltage
system. The proposed circuit is generic in
nature and the voltage range at which level shifting can
be done is limited by the technology only. The circuits
was designed in 90nm CMOS technology and
simulated in SPICE. The simulation results show that
the proposed level shifter circuit is able to shift the
input signal from 1.2V to 2.5V at maximum frequency
of 500MHz.
发表于 2010-12-15 23:11:29 | 显示全部楼层
不错不错,eetop的大侠就是多
发表于 2011-3-10 19:31:50 | 显示全部楼层
ok,xiexiele
GMT+8, 2025-12-28 13:00 , Processed in 0.017904 second(s), 4 queries , Gzip On, Redis On.
